Hi
1026
03-17-2020 01:38 AM
KaterynaHolubenko
I tried to share Water Distribution Simple Network as Web layer for using it as a server for  Water Editor. I have a problem with publication:
Are these errors possible because of my portal version? I have 10.6, water requirements need to be 10.8.
The version of my weater distribution and possible version of the editor is shown below:
MikeMillerGIS
Esri Frequent Contributor
Kateryna,
   The first screen shot shows warnings.  These are fine.  We provide group layers in the map for organization.  When published as a service, they are removed for you.
   The second issue, you are correct.  We have newer versions of the data model, which require newer versions of portal.  If you need access to the older maps that match your portal, you can manually download the editor project here:
https://www.arcgis.com/home/search.html?q=tags%3A%20deploy.commonid.fb74f2b9-82ee-4683-83e4-14cc6798...
