Error 000732 when importing asset pacakge to SDE in WaterDistributionDataManagementForArcGISEnterprise
5712
11
06-24-2021 01:19 AM
VHolubec
I am trying to load sample data of WaterDistributionDataManagementForArcGISEnterprise v 1.1 to SDE geodatabase (PostgrSQL).
The Tool Apply Asset Package has failed on error: StructureLine does not exist or is not supported (error 000732) when executing Append operation. But this particular Feature class is present in the dataset.
Is there any fix for this issue?
Thank you,
Vladimir
Vladimir
VHolubec
Ok, thank you, It´s good to know that it´s not some general issue. I will discuss it with colleagues from Tech Support.
Just to be sure - ArcGIS PRO 2.8, PostgreSQL 11,  dltsolutions 2.7.1, untools 2.8.1 on Asset Package 2.7 is everything which should work together with Water Management Solution?
If we find a the reason for this/solution I will let you know.
Thank you for you help!
Vladimir
PaulLeBlanc1
Yes, all of those versions are valid.
