Attribute Assistant - generate unique id based on domain value in another field
5503
9
06-24-2020 01:39 AM
JonKwong1
I have parcels with different landuse classes: Business, Residential, etc. I would like to generate a unique id when the parcel is being split. However, I need to generate a different id and counter depending on the landuse class. If Business, then generate B1, B2, B3, etc. If Residential, then generate R1, R2, R3, etc.
This is my progress.
Table NameField NameValue MethodValue InfoOn Create
ParcelPLOT_IDGENERATE_IDCOUNTER_BTRUE
ParcelPLOT_IDGENERATE_IDCOUNTER_RTRUE
ParcelPLOT_IDEXPRESSIONIIf([TYPE]="Business","B" & [PLOT_ID],"")TRUE
ParcelPLOT_IDEXPRESSIONIIf([TYPE]="Residential","R" & [PLOT_ID],"")TRUE
I could not figure out how to trigger it. Any help would be appreciated.
MikeMillerGIS
Esri Frequent Contributor
You can use one seq and put that value in the field and then use an expression to put the proper prefix
MikeMillerGIS
Is the layer subtyped by the type? If so you can specify that in the Table Name, such as Parcel|1. Without that, you cannot use different sequences.
JonKwong1
Unfortunately it is not subtyped.
So, what if both IDs share the same sequence? For example the sequence is B1, B2, B3, R4, R5, R6. If I split R6, I'll get R7. Is that possible?
MikeMillerGIS
JonKwong1
I tried this, but I am not getting expected results.
Table NameField NameValue MethodValue InfoOn CreateRule Weight
ParcelPLOT_IDGENERATE_IDCOUNTERTRUE1
ParcelPLOT_IDEXPRESSIONIIf([TYPE]="Business","B" & [PLOT_ID],IIf([TYPE]="Residential","R" & [PLOT_ID]))TRUE0
MikeMillerGIS
Syntax is not complete, iif(statement, what to do when true, what to do when false)
IIf(="Business","B" & ,IIf(="Residential","R" & ,))
JonKwong1
OK. I tried this with the cut polygon tool but I only get the sequence without the prefix.
ParcelPLOT_IDEXPRESSIONIIf([TYPE]="Business","B" & [PLOT_ID],IIf([TYPE]="Residential","R" & [PLOT_ID], [PLOT_ID]))TRUE0
MikeMillerGIS
Need to turn the log file on and see what it says
JonKwong1
The log is very useful. I found my mistake. Accidentally changed the value method. It is working now. Thanks a lot.
JoeBryant1
This use of the feature class name followed by the subtype number in the Table Name field of the DynamicValue table is an excellent find! I've seen other, less than ideal solutions from ESRI support on how to use different subtypes sequences, but this is the most elegant and easy to implement by far. I just wish it was easier to find in the Attribute Assistant documentation.
