I am trying to migrate our data into the Water Distribution Solutions using ArcGIS Pro. Whenever I add fields and try to save and red block (error 000852) comes up and my fields are not added.
Hi Ivy,
It is likely that error is occuring because you are trying to add a field to a feature service view in ArcGIS Pro, rather than the primary feature service. Fields need to be added to the primary feature service (in Water Distribution Data Management that would be either the WaterDistributionSystem service or the WaterMapNotes service) and then the fields can be added to the views by using Update View in the Settings in ArcGIS Online.
Hi Ivy,
New fields need to be added to the WaterDistributionSystem hosted feature layer.
After adding the required fields, Update the view for each feature service view (WaterDistributionSystem_editing, etc.)
Update View is found on the settings for the item in ArcGIS Online:
Select the layer that has the added field(s), then click "Select Fields":
Click on the new fields to add the check mark, then click done:
I hope that helps!
Hi Ivy,
Hi Ivy,
I hope that helps!
