state-wide project for aquifer mapping
2302
10-21-2013 07:31 PM
RachealJones
I'm calculating areas of aquifers of New Mexico. The state is between two zones and I'll likely need to create my own datum. Does anyone know which system is the best to preserve areas in the State of New Mexico?
MarkBoucher
Honored Contributor
I  could be wrong,  but this might not be the best forum to post this question. If you post it on one of the other communities, you might get a faster and specific response. http://forums.arcgis.com/index.php
MelitaKennedy
Esri Notable Contributor
You should use Albers equal area or Lambert azimuthal equal area to construct a custom projected coordinate system.
Melita
RachealJones
Thank you so much Melita! I found some Texas and California that used those. I appreciate  your help. - R
