Split stream from delineation
2728
04-17-2014 01:31 AM
Dong_EonKim
Hello All,
I need your help. Can I express split river from stream delineation?
Below picture will helpful for you. the number shows the elevation.
[ATTACH=CONFIG]33158[/ATTACH]
Thank you.
MarkBoucher
Honored Contributor
When streams split, they are considered non-dentritic or deranged. In the Arc Hydro environment, there is a way to deal with deranged terrain. Look in the toolbox for Arc Hydro Tools.tbx > Terrain Preprocessing Workflows > Basic Deranged Terrain Processing. This will show you the process for dealing with deranged flows. I have not yet had to deal with this, but the tools and possibly the online help should lead you through it.
