Hi, I have downloaded the arcgis version 10.4 and I need the Archydro tool to work on it. Does anyone knows if there is a version of archydro for arcgis 10.4? Or do i need to download other version of Arcgis? I thought wierd because I got Arcgis from free trial on esri and they gave me version 10.4 and for other friends who did de same, other versions. Thank you!
Arc Hydro for ArcGIS Desktop 10.4 is now available on http://downloads.esri.com/archydro/archydro/setup/10.4/
Christine Dartiguenave
Esri Water Resources Team
Hi Marina,
Arc Hydro for ArcGIS Desktop 10.4 is not released yet. It will be available for download soon on the below mentioned site.
yellow.esri.com - /ArcHydro/ArcHydro/Setup/
I hope this helps!
I uninstalled ArcHydro and installed the version from 6/2/2016 4:43 PM <dir> 10.4.0.3. Things appear to be running OK now. This looks like the latest version even though the data on the directory is not the latest.
I also ran the python version for the Terrain PreProcessing Workflows/Dendritic version and it ran without a hitch.
Mark,
Why install the older 10.4.0.3 (2016-02-06) build instead of the 10.4.0.12 (2016-07-13) build?
Ignore the ASCII sort order the Web server lists in, and go by the build number/date to keep current.
Stuart
Hi Christine,
Will there be a version made for ArcMap 10.4.1.5686? If so, when do you expect this to be available?
Todd
Watching - We just upgraded our University computer labs to 10.4.1 and we regularly use ArcHydro for research and teaching. I'm hoping someone answers our question ASAP
Current 10.4 builds, 10.4.0.24 (2016-12-27) from the Web server runs fine on ArcGIS for Desktop 10.4.1
The 10.5 (10.5.0.8) , and ArcGIS Pro builds of ArcHydro Tools are also available and work (although I've not yet checked the Pro builds against Pro 1.4, but expect it is fine).
Stuart
