HecGeo HMS start new project error
2754
08-17-2010 08:47 AM
ZachEdwards
Hello all, I am experiencing another error with starting a new project in HecGeoHMS. I am starting to think that this is all a compatibility issue with Windows 7. I may try this in XP. I have attached the error. Any help would be great! Thanks!
Eng_A_SH
I think i've encountered such an error before.
I can't remember which solution helped me but try these 3 in separate projects so you can avoid more errors:
- Change the projection of the original DEM that you started the project with. If it's Geographic then project it to a projected coordinate system and vice versa.
- Try putting the output file in the default geodatabase. If that didn't work try putting it in the default geodatabase under a file named " Layers " .
- Try putting Inlets and Outlets instead of just an Outlet.
Hope this helps.
