HEC-GeoRAS - error: protected memory
3153
09-12-2011 05:24 AM
MikkoSane
Dear All,
I have installed HEC-GeoRAS 4.3.93 with ArcGIS 9.3.1.
When I click e.g. button "Assign RiverCode and ReachCode to River" I receive the following error message:
apFWNet
Assign RiverCode/ReachCode activation failure:
HECGeoRAS.clsToolRiverReachID
System.AccessViolationException: Attemped to read or write protected memory. This is often on indication that other memory is corrupt.
  at ESRI.ArcGIS.esriSystem.UIDClass.set_Value(Object guidAsString)
  at ApFWNet.ApConfig.get_Editor()
  at HECGeoRAS.clsToolRiverReachID.OnClick()
Can anyone help what's the problem?
Br,
Mikko
NathanChase
Hi all,
I am getting the same error message as Mikko. I am using a Windows 7 PC with freshly installed ArcGIS 9.3.1 with Arc Hydro Tools 9, GeoRAS 4.3.93, and GeoHMS 4.2.93.
Even for a simple task like �??RAS Geometry | Layer Setup�?� in the toolbar I get this error message:
ApCommand activation failure: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
Has anyone found a way to resolve these errors?
Many thanks,
Nathan
MarkBoucher
Honored Contributor
