HEC-GeoHMS - can't generate project: System.Runtime.InteropServices.COMException erro
5463
5
10-18-2010 12:39 PM
JeffTang
Trying to generate a new HEC-GeoHMS project and coming up with the following error when I click Generate Project:
System.Runtime.InteropServices.COMException (0x80004005): Error HRESULT E_FAIL has been returned from a call to a COM component.
at ESRI.ArcGIS.Geoprocessing.GeoProcessorClass.GetEnvironmentValue(String environmentName)
at HECGeoHMS9.GenerateProject.UpdateAHD(String rasterLocation, String vectorLocation, String ahProjName)
I was able to generate the project before with my draft files, but since finalizing our DEM, I can't seem to get past this error.  Any ideas?
JeffTang
I've ran the workspace on 2 computers...desktop and laptop...both using Win 7 64-bit and still the same error message.
I was trying to follow the tutorial at:
http://web.ics.purdue.edu/~vmerwade/education/geohms.pdf
In that example, they have a zip file that has all the raster datasets and a geohms.mdb which contains the necessary vector data.  I'm not sure how they got the vector data into the geohms.mdb...did they just copy the terrain preprocessing mdb file and rename it? or is their a method in setting that up?  the User Manual is vague on how to setup the HEC-GeoHMS process.  Perhaps someone can chime in on how they go about setting it up.  Thanks!
jaimemaestre_amaya
i have the same problem. I reinstall everything again and I came out this error with archydro tools 1.3 y HEC-GeoHMS 4.2.93 for ArcGIS 9.3. see the attached thumbnails
YUTINGLin
I have the same problem.I came out this error with Arc Hydro and HEC-GeoHMS for ArcGIS 10 .1 (version 10.1, May 13 2013).Any way to solve it?
AndrewMartinez1
I'm having the same problem.  What format is your DEM and what are the units of elevation?
YUTINGLin
My DEM is 40mx40m and the units of elevation is m.
