Floodplain Delineation Using Grids
3887
11-20-2013 06:10 PM
ShikoNjuno
Hi folks,
I'm hoping someone can help me resolve this issue.
I'm trying to run the for-mentioned tool in ArcGIS but I keep getting this error.
[ATTACH=CONFIG]29257[/ATTACH]
I have no idea where to start troubleshooting so I was wondering if any of you have ever experienced this before.
Any suggestions welcome.
Shiko
MattMead
Georas does weird things when you try working with grids. The georas mapper is such a black box we dont even try to use it anymore.  Based on the line in the error saying its possibly an empty feature class as an output I would first verify that all of your files are in the same spatial reference.
Do you have a 3dAnalyst license?  If so, I would convert your terrain and water surface grids to TINs.  Then you can use 3dAnalyst-> Triangulated Surface->Surface Difference.
This outputs a polygon shapefile of your floodplain and has the option to output a depth grid as well.  Hope that helps.
