Geo-HMS menu missing
2588
12-03-2012 05:38 AM
ROBINWILLIAMS1
I am using ArcMap 10 under Windows 7 64 bit and I am not seeing the Basin Processing menu on the GeoHMS toolbar when using GeoHMS 10.0.0.70 or 10.0.0.95.
Any suggesetions?
I have uninstalled and rebooted and installed.... and still no "Basin Processing" menu on the toolbar.  I cannot split a basin or merge because I do not see the menu.
Thanks in advance!
V_StuartFoote
Robin,
Attached is a snip of the default HEC-GeoHMS toolbar from 10.0.0.95
Two things to try:
1) Use the ArcMap -> Customize -> Customize Mode and highlight the GeoHMS toolbar. Then use the Reset button (see attached images).
2) Delete your user AppData profile (C:\Users\YourUserName\AppData\Local\ESRI and ...\AppData\Roaming\ESRI) and your per user Registry configuration. E.g. HKEY_CURRENT_USER\Software\ESRI.
Then allow them to rebuild with defaults on next launch.
See if either will get you back to default toolbar.
Stuart
ROBINWILLIAMS1
Doing the second suggestion did the trick!  Thank you!
