Flow Path tracing+model
4807
01-26-2013 07:14 AM
meriyalootka
Hi
How can I find "Flow Path tracing" script? It is not in ArcHydro Toolbox. I need it for geoprocessing.
Regards
ChristineDartiguenave
There is one geoprocessing tool in the Arc Hydro Toolbox in the Point Characterization toolset called Generate Flow Path.
It takes as input the source points to trace, the flow direction grid as well as the Catchment and Drainage Line feature classes to speed up performance. It generates the flow paths. You may want to check it out.
Christine Dartiguenave
Esri Water Resources Team
meriyalootka
How should I generate catchment and drainage Line feature classes?
MarkBoucher
Honored Contributor
Arc Hydro is a good tool to use. Here are several links that will give you tips on Arc Hydro.
http://forums.arcgis.com/threads/53316-Why-can-t-I-define-a-stream-network
http://forums.arcgis.com/threads/48100-ArcHydro-Problem-Solvers
AmirNajian
I have all the required input datasets for Generate Flow Path tool but when I run this tool, it give me this error message:"DrainID does not exist for DrainageLine!". I don't know what step I'm missing in terms of adding DrainID to my layers. I used ArcHydro ModelBuilders from ArcHydro Tools>Terrain Processing Workflows to generate the input rasters and feature classes.
Thank you.
