extract max raster cell value to a point
4542
07-21-2012 10:41 AM
CarlStearns1
I'm trying to extract the max cell value as a point that I can use in a cost path calculation. Any suggestions?
Carl
CarlStearns1
I had an idea yesterday that I'll try: get max value, then using raster calculator, subtract max value then set negative values to no data, then convert raster to point. This is part of a python script I'm writing so I'll report back when I get a chance to see how it works. If anyone else has a better idea please share. Thanks!
MarkBoucher
Honored Contributor
It seems like you could determine the max value and then use the CON() function to set everything that is not the max value to 0 or null and then convert that to a point.
