error in  DEM Reconditioning
7521
6
02-18-2013 07:39 AM
NohaAbd_Al_Warth
Hello,
i am a beginner in Arc Hydro and i am using the arc hydro tools 2.0 tutorials.
when trying the DEM Reconditioning tool, I get the following error:
"ERROR 010024 : Error during conversion."
" failed to execute (DEM Reconditioning) "
how to solve the error ?
MarkBoucher
Honored Contributor
NohaAbd_Al_Warth
Look for solutions at this post:
http://forums.arcgis.com/threads/48100-ArcHydro-Problem-Solvers
i tried to this solutions but failed
MarkBoucher
Honored Contributor
I Google searched the error and found this.
Error in DEM Reconditioning in Arc hydro 10
MarkBoucher
Honored Contributor
I search using "010024 : Error during conversion" and found: http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00vq00000002010024.htm
Based on that:
  • Make sure your layers are in the correct coordinate systems.
  • Make sure your processing extent covers your work area.
  • Make sure the raster is floating point.
  • Make sure you have permissions to read/write to the directories and files.
DanWismer
Hello everyone,
All my DEM Reconditioning problems have always been solved by making sure my raster DEM and vector RIVER layers are in the same geographic and projected coordinate system.
DanWismer
I would also follow Mark's advice by setting up the target vector and raster workspaces, setting the processing extent to the appropriate level, working off my local 'C:' drive, making sure my vector attribute table has the appropriate information in order to satisfy the tool inputs and then cross my fingers.
