Elevation differences at junctions of polygon rivers
1723
01-06-2014 07:24 AM
BenLeonard
I am mapping out a delta area with  hundreds of polygon rivers.  The rivers all need to monotonic, and I am using LiDAR data.  After draping the vector lines to the .las file and then flattening the rivers, the intersection between secondary rivers and the primary rivers have a small elevation difference.  Is there a solution to this problem, without having to go to each intersection and changing the Z elevations by hand to make sure that rivers stay monotonic?
