Depression Evaluation
1077
11-07-2019 03:20 PM
TenorioBrito
Hello guys,
I have been seeking help to solve this problem, but I have not succeeded. Whenever I try to run the Depression Evaluation ArcGIS spends about 1 hour processing and in the end presents this message:
Could someone help me?
GarretDuffy
I have encountered this error and it is not terminal. From (distant) memory, some things to try are:
  1. Check the "Target Locations" are specified and correct
  2. Resave a new MXD file
  3. Make sure input file is GRID format
  4. Make sure output filename conforms to GRID filename requirements (number of character, no leading numbers, etc) and does not have file extension
Note that for fast troubleshooting you can set the Processing Extent environment variable to "Same as Display" and set the display to a small area.
Good luck.
