Basin Header Table missing/name
1698
11-18-2016 05:05 PM
TalhaMahmood
Dear All,
 I hope everyone is doing fine.
I am new to HEC-HMS. Everything went fine until map to Hec-Hms unit in Hecgeohms toolbar in arcgis 10.2.
the problem is whenever i click on map to HEC-HMS unit the problem pop up BasinHeader table could not be found. All tables are in main geodatabase. So I wanted to ask how i can solve this problem? Can I make basin header table on my own? Can some one share his basinheader table so I can follow on same lines. Or under hat name HEcgeohms create basin header table because Hecgeohms create lot of tables so can you guys tell me under which name it is so may be i can import it in arcmap manulay. pleases help me I will be thankful to you guys.
Thanks in Advance
