ArcGis 10 -> GeoTiff for TauDem5
1223
05-03-2011 11:58 PM
PhilGlingener
Hi!
I'm trying to use TauDem5 to create flow directions for a DEM by using the DInf algorithm. First of all, I did an interpolation (IDW) of points inported from text files with ArcGis10. Afterwards, I exported the DEM as .tif - file to use it as input for the DInfFlowDir-tool from TauDem. Everytime I'm trying to execute this process via command line, I'm getting this error:
Error opening file .
application calles MPI_Abort(MPI_COMM_WORLD, 22) - process 0
I'm not sure what's wrong here. Is it an issue of the installation or maybe the wrong output format?
I would appreciate your help with this!
Thanks a lot!
Best regards!
MollyMartin
Has anybody figured out a solution to this error? I am attempting to do the same thing, my input is a GeoTiff and I still get this error.
application called MPI_Abort(MPI_COMM_WORLD, 22) - process 0
Error opening file <file name>.
TauDEM input files have to be GeoTiff files.
I have not found any documentation on this, if anyone else has run into this I would appreciate your insight!
Thank you!
ducksunlimited
mart2409 - have you fixed the issue?
I had the exact issue - "TauDEM input files have to be GeoTiff files".
Thank you!
ThomasColson
MVP Alum
All of these errors indicate that MPI is not installed correctly. I recall it was a big ordeal to get MPI to work. Go to MPI website and follow their installation/troubleshooting.
