Dotted lines bug
3230
07-14-2014 09:23 PM
DenisLashkov
Sometimes new dotted lines (created in template) become solid or appear wrong. Dots may disappear or place too close to each other if the angle of the line changes.
Don't know how to solve this problem, help please
Regards.
Tags (1)
PaulHickson
Hello Denis when you say template what do you mean?
Are you using desktop or online
what version are you using?
DenisLashkov
Hello Paul, I'm using ArcGis Desktop v10. Template in line properties i mean. I think it's even doesn't matter, because the same bug happens with ESRI lines/
Thanks for quick answer
PaulHickson
TThanks Denis
there might be a little pixel issue with this I notice you are using points which shoul be fine but have you tried a measured value like 5 mm?
DenisLashkov
Hello Paul. Thanks for your advice, but setting different units doesn't help. Lines look right if I save low quality picture (96 dpi and lower), but such image doesn't satisfy me. Don't know what "the most powerfull computer" should I have to save at least 150dpi.(6500*9000px)
SteveCole
Honored Contributor
NO- there is not (at least for free). This year, ESRI kept quiet that the technical workshop presentations, which were provided to all conference attendees via DVD after the conference, were no longer being provided.
If you wanted to obtain them, you would have to purchase them through a third party. There was a "discounted" conference rate of $300 which jumped up to $500. Again, this USED to be included with your registration costs but no longer.
The website for the third party is: https://www.esrionline.com/
