Where can I get network dataset?
1878
03-19-2019 11:21 PM
재원김
Hi, guys.
I'm asking you a question because I need your help.
I'm trying to design a route from a few points in the Shanghai area of China, using the Network Analysis feature of the ArcGIS Desktop version.
As you know, you basically need a network dataset to use the Network Analysis feature.
However, I searched for data for several days, but I couldn't find a shape file that contained distance and speed information for each section.
Therefore, if there is a network dataset with streets and speeds in the Shanghai area, please share them.
Or, I'd appreciate it if you gave me a site or information where I could get the data.
Thanks.
DerekLaw
Esri Esteemed Contributor
Hi 재원 김,
These 2 sites might have the street data you're looking for:
Once you get the street data, you'll have to use the Network Analyst extension to "compile" the data into a network dataset.
Hope this helps,
