I would like some clarification. I have a table of orders that I have an X and Y location (currently in CA State Plane coordinate value). I have mapped the ArcLogistics X and Y fields using the X and Y values in both text and double data types. In either case, I can get the locations to show up in an order box, but when I try to assign them to a truck, the data does not load. the Geocoding field in the unassigned box all indicate Import XY. To my understanding, this should be sufficient with ArcLogistics for routing and sequency, however, this does not seem to be the case. If I leave off the X and Y fields and use only the address, then the data does get imported, the Geocode field indicates Address, City, State and then when I select some of them to assign to a truck, a route is produced.
Am I missing something? Since I have high confidence in my XY location for my "address" location, I would like to take advantage of this if possible for routing purposes. I know the current data does not show a city or a state, but they are all in Sacramento, CA.
Any insight is appreciated.
Nate
