Trouble exporting from model builder to python script
3937
05-02-2011 11:35 AM
by Anonymous User
Not applicable
Original User: Kreeves11674
I built a model that would copy mutiple feature datasets from one ArcSDE to another. In the model, everything worked fine. It would copy all six (6) feature datasets over. But once I exported the model to a python script, and ran it, it would only copy over the first feature dataset that was listed.
Is there something that I missed in the export process?  I am new to model builder and python, so please bear with me.  There are supposed to be 6 datasets to be copied, but the attached screenshot only shows one of them in the python script.  Any help would be greatly appreciated.
Kevin
MathewCoyle
Honored Contributor
You need to make a list of your datasets and loop through them. I don't think python will be able to recognize multiple inputs through one copy tool. Something like this.
sde1 = #your source connection
sde2 = #your output connection
arcpy.env.workspace = sde1
datasetList = [dataset1, dataset2,...]
for dataset in datasetList:
    arcpy.Copy_management(dataset, sde2+dataset)
If you want to get ALL the datasets from an SDE GDB then you can also just do
datasetList = arcpy.ListDatasets("", "Feature")
