Spatial Reference question
3679
11-28-2012 09:57 AM
by Anonymous User
Not applicable
Original User: luke.kaim
Hi Everyone,
I am using the search cursor. I want to change the spatial reference on the fly. I believe this can be done with spatial_reference.
the input shapefile is in UTM 19N. I want the extents to be in DD. I know I could reproject, but I want to get better at python. What am I doing wrong?
I used the python window in ArcGIS.
sCur = arcpy.SearchCursor("boundingbox1", "", "CCS_WGS_1984") ... for row in sCur: ...     geom = row.shape ...     ext = geom.extent  # or row.Shape.extent ...     print "Extent of feature:\nXMin: %f, YMin: %f, \nXMax: %f, YMax: %f" % \ ...           (ext.XMin,ext.YMin,ext.XMax,ext.YMax)
Thank you,
Luke Kaim
Thank you
Luke Kaim (SIE)
[email protected]
(914)263-7866
"Don???t complain. Just work harder" (Randy Pausch).
by Anonymous User
Not applicable
Original User: JSkinn3
Hi Luke,
If your current UTM coordinate system is in the WGS_1984 datum you won't have to apply a transformation, so you could use the WKID in the SearchCursor.  Example:
sCur = arcpy.SearchCursor("boundingbox1", "", 4326)     for row in sCur:         geom = row.shape         ext = geom.extent  # or row.Shape.extent         print "Extent of feature:\nXMin: %f, YMin: %f, \nXMax: %f, YMax: %f" % (ext.XMin,ext.YMin,ext.XMax,ext.YMax)
You can easily obtain the WKID by selecting the coordinate system in the Data Frame Properties and looking at the details under 'Current Coordinate System'.
curtvprice
An approach that may work for you is to try the ProjectAs method of the geometry object to create a new geometry in the new coordinate system.
Geometry (arcpy)
http://resources.arcgis.com/en/help/main/10.1/index.html#//018z00000070000000
by Anonymous User
Not applicable
Hi Luke,
