Spatial Reference grab not working...
5219
11
02-27-2013 11:42 AM
by Anonymous User
Not applicable
Original User: SStrand
I have a large metadata generating script that is working great, except for some reason the spatial reference of the data being grabbed and wrote to a Word file is not working.
First, the portion to write text to word (this works fine for all other instances in the script):
def search_replace_all(newword, find_str, replace_str):
    wdFindContinue = 1
    wdReplaceAll = 2
    app = win32com.client.Dispatch("Word.Application")
    app.Visible = 0
    app.DisplayAlerts = 0
    app.Documents.Open(newword)
    app.Selection.Find.Execute(find_str, False, False, False, False, False, \
        True, wdFindContinue, False, replace_str, wdReplaceAll)
    app.ActiveDocument.Close(SaveChanges=True)
    app.Quit()
search_replace_all(newword, olddate, newdate)
Here is the code that isn't working:
spatialdesc = arcpy.Describe(newlayer)
sr = spatialdesc.SpatialReference
newspatial = sr.Name
search_replace_all(newword, oldspatial, newspatial)
I've also seen this as/tried unsuccesfully in my code:
sr = arcpy.Describe(newlayer).spatialReference
newspatial = sr.name
All I get is a generic script error failure response when it gets to this point. Any ideas as to why it won't complete this part correctly?
I am using ArcGIS 10.0 SP3, Windows 7, Python 2.7
MathewCoyle
Honored Contributor
How are you generating the oldspatial variable? Can you print out all the names you are passing to your word writing function in the interpreter before you attempt to call the function?
by Anonymous User
Not applicable
So the way it works is I have a template word file that is copied and then edited with metadata information from a variety of sources, including the layer I am working with. 'Oldspatial' is the filler text in the template word file that is replaced by the actual spatial reference 'newspatial'.
newlayer = arcpy.GetParameterAsText(0)
newlayername = arcpy.GetParameterAsText(1)
newdate = arcpy.GetParameterAsText(4)
tempword = "K:\\SDE_System\\metadata\\AGS10_Metadata\\_gis_metadata_template.doc"
tempdir = os.path.dirname(tempword)
newword = os.path.join(tempdir, newlayername + ".doc")
olddate = "06/09/2000"
oldspatial = "ie: State Plane California 6 Feet"
These are all related to what I have posted code wise.
by Anonymous User
Not applicable
Just ran the script with
arcpy.AddMessage("test")
before the
and it failed without displaying the name. There is already an arcpy.AddMessage("The document is X% complete") right before
so something is going wrong in there...
MathewCoyle
Honored Contributor
How are you passing this parameter to your tool? Object, string, something else?
by Anonymous User
Not applicable
In the script properties it is a Layer data type, to allow for a drop down of available layers in the ArcMap document. In the ArcGIS help under describe it made it sound like that wasn't an issue.
DarrenWiens2
Does it work with the capitalization shown below?
sr = spatialdesc.spatialReference
edit: I should add, this works for me
by Anonymous User
Not applicable
Nope, that is actually how I originally had it until, while researching possible issues, I came across this page which had it the current way.
Edit: I don't believe the code is wrong...but I have no clue why it is failing.
MathewCoyle
Honored Contributor
This code works fine for me.
import arcpy
def main(layer):
    spatialdesc = arcpy.Describe(layer)
    arcpy.AddMessage(newspatial)
if __name__ == '__main__':
    main(layer)
The only other issue I can think of it being is something wonky with your 2.7 install and arcpy not playing nicely.
by Anonymous User
Not applicable
I'll try it out on another computer here and see how it goes.
