SelectLayerByLocation returning incorrect
2377
02-07-2013 07:57 PM
by Anonymous User
Not applicable
Original User: ahrensd
Have been trying for some time now to create a script to extract the polygons whithin a extent, but unable to get the same result as when i use the UI manual method.
Maybe someone can see the fault of my script, have striped it down to the minimum for simplicity.
import arcpy
layer = arcpy.GetParameterAsText(0)
top = arcpy.GetParameterAsText(1)
left = arcpy.GetParameterAsText(2)
bottom = arcpy.GetParameterAsText(3)
right = arcpy.GetParameterAsText(4)
outputFeature = arcpy.GetParameterAsText(5)
# Determine if Layer is a Layer
desc = arcpy.Describe(layer)
if hasattr(desc, "layer"):
     lyr = layer
     arcpy.AddMessage('Parameter was layer: {0}'.format(lyr))
else:
     lyr = arcpy.MakeFeatureLayer_management(layer,"in_memory\\source_layer")
     arcpy.AddMessage('Parameter made to layer: {0}'.format(lyr))
sr = arcpy.CreateSpatialReference_management("",lyr,"","","","")
lowerLeft = arcpy.Point(left,bottom)
upperLeft = arcpy.Point(left,top)
upperRight = arcpy.Point(right,top)
lowerRight = arcpy.Point(right,bottom)
a = arcpy.Array([lowerLeft,lowerRight,upperRight,upperLeft,lowerLeft])
thepoly = arcpy.Polygon(a,sr)
arcpy.AddMessage('Selecting form lyr by polygon: {0}'.format(thepoly))
selection = arcpy.SelectLayerByLocation_management(lyr, "WITHIN", thepoly, "", "NEW_SELECTION")
matchcount = int(arcpy.GetCount_management(selection).getOutput(0))
if matchcount == 0:
    arcpy.AddMessage('no features matched spatial and attribute criteria')
else:
    if matchcount < 1000:
        arcpy.CopyFeatures_management(selection, outputFeature)
        arcpy.AddMessage('{0} objects that matched criteria written to {1}'.format(matchcount, outputFeature))
by Anonymous User
Not applicable
Original User: Wayne_Whitley
Yes, well, aren't you getting the point object's XY parameters at the beginning of the script as text?  The webhelp doc explicitly states you have to feed in double data types....so I think in Python you'd need to convert to float, as in (using IDLE):
>>> text = '123.456'
>>> type(text)
<type 'str'>
>>> num = float(text)
>>> type(num)
<type 'float'>
>>> # text cannot be used directly in, say, math operations:
>>> text + 1.0
  File "<pyshell#15>", line 1, in <module>
    text + 1.0
TypeError: cannot concatenate 'str' and 'float' objects
>>> # However, the converted value can:
>>> num + 1.0
124.456
Fix that, see if it runs...
Enjoy,
Wayne
