Script works in python win but does not in al toolbox within ArcMAP
10242
10
02-20-2014 05:35 AM
by Anonymous User
Not applicable
Original User: af.ramirez
Hi everybody...
I've been developing a quite long script, and I tested it in PyScripter an IDLE when it was finished.... well it works perfectly, so I added it to a toolbox in ArcMAP and when I ran it it did not work....
I have spent many days trying to figure out what the problem is but until now it has been imposible...
This is a piece of the code where the error comes out...
print "Startin iterations"
    print datetime.datetime.now()
    fields= ("FID", "avg_mindis", "I_conc", "Max_lenght","TamanoTerr")
    ##create UpdateCursor and iterate trough each register
    with arcpy.da.UpdateCursor(territory,  fields) as cursor:
        for row in cursor:
            currentID= row[0]
            #print currentID
            ## select current cell with current FID
           where= " FID = " + str(currentID)
            arcpy.SelectLayerByAttribute_management(territory_lyr, "NEW_SELECTION", where )
            arcpy.SelectLayerByLocation_management(eventos_lyr, "INTERSECT", territory_lyr, "" , "NEW_SELECTION")
I don't know if maybe there is a problem with the selection by attributes...
Appreciate any help..
Felipe Ramirez
GIS Analyst
[ATTACH=CONFIG]31617[/ATTACH]
by Anonymous User
Not applicable
Original User: AdamCox
Hi Felipe, can you describe the error that you get?  Are you using any error handling?
Andres_FelipeRamirez_Mejia
Hi....
I have a try - Except sentence starting before this line with arcpy.da.UpdateCursor(territory, fields) as cursor:
and the error I get is this
by Anonymous User
Not applicable
hmm, if you import the sys and traceback modules, you can add this code in the except statement:
tb = sys.exc_info()[2]
tbinfo = traceback.format_tb(tb)[0]
pymsg = "PYTHON ERRORS:\nTraceback Info:\n" + tbinfo + "\nError Info:\n     "\
                + str(sys.exc_type) + ": " + str(sys.exc_value) + "\n"
msgs = "ARCPY ERRORS:\n" + arcpy.GetMessages(2) + "\n"
print pymsg
print msgs
Hopefully you can get more detailed information about what's going on.
Hi Adam...
I added the code you gave me and the new nessages didn't show new info about what's going on...
look at the messages...
[ATTACH=CONFIG]31634[/ATTACH]
by Anonymous User
Not applicable
Ok, I don't know the earlier parts of your code, but perhaps there is an issue with how you are creating the layers and/or getting them from the tool parameters... assuming you are running it through a tool dialogue box.  It may also have to do with the parameter types you are using in the dialogue box.  Can you pass that information along?
Hi Adam...
Here is an example of the code...with some modifications
import arcpy
import datetime
import os
import sys
import traceback
arcpy.env.overwriteOutput = True
territory= arcpy.GetParameterAsText(0)
path= arcpy.GetParameterAsText(1)
arcpy.MakeFeatureLayer_management(territory,"territory_lyr")
fldFID = arcpy.Describe(territory).OIDFieldName
print "ID: "+fldFID
fields= (fldFID, "avg_mindis", "I_conc", "Max_lenght","TamanoTerr")
try:
        for row in cursor:
            currentID = row[0]
            where = "{0}={1}".format(arcpy.AddFieldDelimiters(territory, fldFID), currentID)
            print "where: "+where
            arcpy.SelectLayerByAttribute_management("territory_lyr", "NEW_SELECTION", where)
            print "Selection ok"
except Exception as e:
    print pymsg
    print msgs
and the error is....[ATTACH=CONFIG]31637[/ATTACH]
by Anonymous User
Not applicable
Hi Adam...
import arcpy
import datetime
import os
import sys
import traceback
print "ID: "+fldFID
try:
        for row in cursor:
            currentID = row[0]
    print pymsg
    print msgs
and the parameters are...
by Anonymous User
Not applicable
I may have found the error: in the code you posted, you need to have "territory_lyr" as the first parameter in AddFieldDelimiters, right now you have the territory string, so that is probably causing an issue with the query.  It would be good to use "territory_lyr" in the Describe method as well.
Hi Adam...
I tried the things you suggested but the didn't work...
The same error message comes out...
I don't know what else I can do....
