overwriteOutput syntax
6296
07-02-2012 07:51 AM
by Anonymous User
Not applicable
Original User: MCline19
I am very new to python and am having trouble getting the correct syntax to overwrite existing files.  Using the syntax I have now, the process appends a "_1" to the new output file.  Currently my syntax reads:
import arcpy
for x in sdeFiles: #sdeFiles is a list
     arcpy.env.overwriteOutput = True
     arcpy.FeatureClassToShapefile_conversion(x,'G:\GISAdmin\SDE_Backups\NewTempShapefiles')
Any advise on how to resolve this issue would be greatly appreciated.  Thanks!
MichaelMiller2
Try:
arcpy.env.overwriteOutput = 1
by Anonymous User
Not applicable
It still appended a "_1".   😞
KimOllivier
Honored Contributor
You have a missing r tag to make the path work as a raw string with backslashes, but that is not the issue.
The help clearly says that it will append _1 if the file exists, so it obviously does not honour the environment setting.
So just check if it exists and delete it yourself.
arcpy.env.workspace = "destination_folder"
if arcpy.Exists(x):
     arcpy.management.Delete(x)
arcpy.conversion.FeatureClassToShapefile(x,"destination_folder")
by Anonymous User
Not applicable
That works.  Good advise!  Thank you.
GerickeCook
I had similar issues until I got it to work in my code by using
overwriteOutput = 'True'
