Opening MS Access Form with Query
6533
05-06-2013 11:14 AM
by Anonymous User
Not applicable
Original User: wjackson
My little Python script is intended to run in a Python-Addin tool where the user clicks on a parcel, grabs the PIN attribute and then opens an MS Access form with the PIN as a parameter to a query. I'm very close to getting this working but can't seem to get Access to open the form with the parameter.
Thanks again to Mike Hunter for the assist with the parcel feature selection.
import arcpy
from arcpy import env
import pythonaddins
import win32com.client, types, pythoncom, sys, os, string
import subprocess
class ToolClass2(object):
    """Implementation for ArcGISAddins_addin.tool (Tool)"""
    def onMouseDownMap(self, x, y, button, shift):
        # set up environment
        arcpy.env.workspace = "C:/temp/python/test.gdb"
        Parcels = "C:/temp/python/test.gdb/Parcels"
        mxd = arcpy.mapping.MapDocument("current")
        df = mxd.activeDataFrame
        # build point geometry, run your getSearchDistanceInches function
        pointGeom = arcpy.PointGeometry(arcpy.Point(x, y), mxd.activeDataFrame.spatialReference)
        #searchdistance = getSearchDistanceInches(df.scale, 3)
        # make an arcpy.mapping layer obj and do the selection by location
        plyr = arcpy.mapping.Layer(Parcels)
        arcpy.SelectLayerByLocation_management(plyr, "INTERSECT", pointGeom, "0 meters","NEW_SELECTION")
        arcpy.CopyFeatures_management(plyr, "climate")
        fc = "C:/temp/python/test.gdb/selected_parcel"
        # Create a search cursor
        rows = arcpy.SearchCursor(fc)
        # Create a list of string fields
        fields = arcpy.ListFields(fc, "", "String")
        for row in rows:
            for field in fields:
                if field.name == "PIN":
                    pin = row.getValue(field.name)
                    out = "%s: Value = %s" % (field.name, pin)
                    pythonaddins.MessageBox(out, "My Coordinates")
        # all done, now add our layer to the map
        #arcpy.mapping.AddLayer(df, plyr, "BOTTOM")
        #arcpy.RefreshActiveView()
strDbName = "BloomingtonQuad.mdb"
#print strDbName
PIN = "2123301001"
path = "N:/Work/20130419_COBTA_Application/Query_BlmTransfer"
accapp = win32com.client.Dispatch("Access.Application")
accapp.Visible = True
accapp.opencurrentdatabase(path + '/' + strDbName, False)
accapp.OpenForm(frmQuad)
accapp.Forms("frmQuad").controls("TxtID").Value = PIN
#accapp.Application.CloseCurrentDatabase()
#accapp.Application.Quit()
TonyAlmeida
MVP Regular Contributor
Hope this helps.
import subprocess
subprocess.Popen([r'C:\Program Files\Microsoft Office\Office12\MSACCESS.EXE',r'\\vopcc\gis\GISOPS\StreetNetwork\Routing.mdb'])
import subprocess
subprocess.Popen([r'C:\Program Files\Microsoft Office\OFFICE11\EXCEL.exe',r'C:\GIS Projects\TaxChange\Export\Change.xls']
by Anonymous User
Not applicable
Tony,
Thanks, I was able to get this working similar to VBA using the following:
strDbName = "access.mdb"
path = "C:/Some_Path"
accapp.openform("frmMyForm")
accapp.Forms("frmMyForm").controls("TxtID").Value = pin
Hope this helps.
import subprocess
import subprocess
Pierre-ÉtienneLord
I am currently trying to make the same development. I am not able to display to the MS Access form. I managed to open the DB but not the form with the clause "where".
Did you create an event on your MS Access form? Thus, would it be possible to share this event code or the complete MS Access mdb?
Pierre
