Object Reference not set to an instance of an object
6153
08-17-2012 06:50 AM
JohnDye
I'm trying to batch a trade area creation process. We have over a thousand of them to do but I'm just testing with 5 tables right now. In any case, I've created the script but it keeps erroring out with the error:
An unhandled exception has occured in Business Analyst. Please contact your system Administrator.
Object reference not set to an instance of an object.
I've embeded a copy of the script and the error I'm receiving. I can't click on details because I have to cancel the script first...which it won't cancel so I have to shut it down via the Task Manager which closes the entire ArcGIS application I'm running the script tool from.
[ATTACH=CONFIG]17039[/ATTACH]
[ATTACH=CONFIG]17041[/ATTACH]
MikeHunter
I'm not that familiar with the functions you are using, but right off the bat I notice that the name "Table" is unreferenced in the line with ValidateTableName.  That's supposed to be a string denoting the name of the table in the given workspace.  The name Table at this point in your script does not point to anything.
good luck,
Mike
by Anonymous User
Not applicable
Original User: johnmdye
Thanks Mahunter243,
ESRI Technical Support pointed out the same thing. I moved the OutFC reference to be inside the loop so that it can reference the table created by the for loop. However, that didn't change anything. I still received the same error. Here's a copy of the updated script and the persisting error. I even tried just completely removing the arcpy.ValidateTableName function and just using the table name by naming the output feature class as <Table + "_TradeArea"> but still received the object not referenced error.
[ATTACH=CONFIG]17211[/ATTACH]
[ATTACH=CONFIG]17213[/ATTACH]
JohnDye
Update: There was an issue with the table schema, not the code.
