Need Info about ArcLog DB access API
2865
10-28-2010 08:18 PM
FerozSoudagar
Hi
I am evaluating Arc Logistics 9.3 SP2.
Are there APIs available to directly create orders without having to use the import wizard.
Similarly are there APIs available to extra teh routing info without havng to go with the export wizard.
Appreciate your advise.
Thanks and regards
Feroz
JeffWickstrom
Hello Feroz,
Yes there is an API which works great for custom imports and exports.  You add a custom button to kick of your code.  The ArcLogistics software CD has several samples, a diagram and a small guide to help you get started.  When you need help, ask a question here.
Jeff
FerozSoudagar
Thanks Jeff. I believe we can also write an "external program"  to push orders to ArcLog using the same API without a need to have a button in ArcLog UI as a plug in.
Best Regards
Feroz
JeffWickstrom
Hello Feroz,
Yes you can use the API to push data to ArcLogistics from an external program or application.  The ExternalAddData sample does something similar from a console app.
Jeff
