Model converted to Script -  Why Can't it find the field?
10167
12
09-30-2013 12:50 PM
by Anonymous User
Not applicable
Original User: ionara_wilson
I have a model that an ESRI associate sent me as an example. When I run the model everything is great.
But I need to have it as a script so I converted it to a script and set the Selecting Features parameter to be a "Feature Set"  and have a schema of a polygon layer. However when I convert this model to a script and try to run as a script, I get an error saying it cannot find the EditField. However the EditField should have been copied to the layer in the Make Feature Layer process. It is not clear why it cannot find the EditField ! Any help?
The first picture shows the model,  the second shows the model when I run it, the third shows the error I get, and the fourth shows the parameters I set before I run the tool. Thank you!!!
[ATTACH=CONFIG]27890[/ATTACH][ATTACH=CONFIG]27891[/ATTACH]
[ATTACH=CONFIG]27892[/ATTACH][ATTACH=CONFIG]27893[/ATTACH]
# -*- coding: utf-8 -*- # --------------------------------------------------------------------------- # calcfeatures_script.py # Created on: 2013-09-30 15:22:46.00000 #   (generated by ArcGIS/ModelBuilder) # Usage: calcfeatures_script <Selecting_Features> <value>  # Description:  # test # ---------------------------------------------------------------------------  # Import arcpy module import arcpy  # Script arguments Selecting_Features = arcpy.GetParameterAsText(0) if Selecting_Features == '#' or not Selecting_Features:     Selecting_Features = "in_memory\\{1CFDCCDD-5D8D-42F8-AEB2-E66ED4A51A44}" # provide a default value if unspecified  value = arcpy.GetParameterAsText(1)  # Local variables: Input_Points = "D:\\ArcGISData\\ESRI_GEO_EX\\GDB.gdb\\SamplePoints" Final_Output = value Selected_Features = Selecting_Features Input_Points_Layer = "SamplePoints_Layer"  # Process: Make Feature Layer arcpy.MakeFeatureLayer_management(Input_Points, Input_Points_Layer, "", "", "OBJECTID OBJECTID VISIBLE NONE;SymbologyField SymbologyField VISIBLE NONE;DomainField DomainField VISIBLE NONE;Shape Shape VISIBLE NONE;Subtype Subtype VISIBLE NONE;EditField EditField VISIBLE NONE")  # Process: Select Layer By Location arcpy.SelectLayerByLocation_management(Input_Points_Layer, "INTERSECT", Selecting_Features, "", "NEW_SELECTION")  # Process: Calculate Field arcpy.CalculateField_management(Selected_Features, "EditField", "'%value%'", "PYTHON_9.3", "")
by Anonymous User
Not applicable
Original User: Wayne_Whitley
Yes, I see the error now...it's with the expression -- apparently (I always forget about this) it needs to be enclosed in quotes.
I included that at your other thread.  (Probably duplicate threads should be avoided in the future, okay?)
...so try this, substituting for the expression parameter [from my post above it is 'str(value)']:
'"' + value + '"'
All that does is add the quotes...let me know if that works.
by Anonymous User
Not applicable
I figured that you can't really convert a model to a script and think everything is going to work. When I converted the model to script, the calculate field process was referencing Selected_features but selected features was a variable that was equal to Selecting Features which meant nothing. I added the Selected Features variable after the select layer by location and made it equal to the Input_points_layer, which was a real layer created before and already selected. Now I just need to figure out how to get the value for the second parameter, which is just showing %value% and not the value I entered for that parameter.
import arcpy
# Script arguments
# Local variables:
Selected_Features = Input_Points_Layer
TimDonoyou
hi there,
you should just be able to use value as the variable in the calculatefield tool without any % or '
you might need to use str() or int() depending on the field type
hope this helps
cheers
Tim
by Anonymous User
Not applicable
I tried that but I got this error:
Executing: CalcFeatures "Feature Set" sdfgsdfgsdfg
Start Time: Mon Sep 30 16:20:07 2013
Running script CalcFeatures...
  File "D:\ArcGISData\ESRI_GEO_EX\calcfeatures_script.py", line 35, in <module>
    arcpy.CalculateField_management(Selected_Features, "EditField", value2, "PYTHON_9.3", "")
  File "c:\program files (x86)\arcgis\desktop10.1\arcpy\arcpy\management.py", line 3129, in CalculateField
    raise e
ExecuteError: ERROR 000539: Error running expression: sdfgsdfgsdfg
  File "<expression>", line 1, in <module>
NameError: name 'sdfgsdfgsdfg' is not defined
Failed to execute (CalculateField).
Failed to execute (CalcFeatures).
Failed at Mon Sep 30 16:20:08 2013 (Elapsed Time: 1.00 seconds)
# Description:
# test
import arcpy
# Script arguments
value2 = str(value)
# Local variables:
#Final_Output = value
ChrisPedrezuela
I think it should just be
arcpy.CalculateField_management(Selected_Features, "EditField", value, "VB", "")
import arcpy
# Script arguments
# Local variables:
by Anonymous User
Not applicable
No, that did not work
TimDonoyou
just out of interest - why do you makefeaturelayer? and redefine selected_features?
i think you should be able to simplify your script to just:
import arcpy
# Script arguments
# Local variables:
arcpy.SelectLayerByLocation_management(Input_Points, "INTERSECT", Selecting_Features, "", "NEW_SELECTION")
arcpy.CalculateField_management(Input_Points, "EditField", str(value), "PYTHON_9.3")
thanks
Tim
by Anonymous User
Not applicable
Good work, Tim...I referred her look here again at her other thread.
ionarawilson1
Thank you Tim. When I run that script you provided I get an error though. Don't I have to have a layer instead of a feature class to do a selection?
  File "D:\ArcGISData\ESRI_GEO_EX\calcfeatures_script.py", line 22, in <module>
  File "c:\program files (x86)\arcgis\desktop10.1\arcpy\arcpy\management.py", line 6559, in SelectLayerByLocation
    raise e
ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000368: Invalid input data.
Failed to execute (SelectLayerByLocation).
by Anonymous User
Not applicable
Ah, good catch, directly from the 10.1 help the 1st parameter which is the layer you are selecting from must be a feature layer:
"The input can be a layer in the ArcMap table of contents, or a layer created in ArcCatalog or in scripts using the Make Feature Layer tool. The input cannot be the path to a feature class on disk."
I think the 'select layer' or the layer/fc you are using to select with can be an fc...both can be a layer if I'm not mistaken - what's interesting is you can fetch layer references from your map, i.e. feed in layer objects.
So, try this:
import arcpy
# Script arguments
Input_Points = arcpy.GetParameterAsText(0)
# Local variables:
Selecting_Features = r' enter path to your selecting features '
And if you want to define a 3rd input parameter to select a layer from the map for Selecting_Features, that should be an option available to you --- that's what you have to test to confirm.
