Issue with Mosaic to New Raster tool
759
09-01-2011 09:10 PM
by Anonymous User
Not applicable
Original User: corea
I am having a major issue with the Mosaic to New Raster tool when importing ASC files. It processes the first few files but not all of them. I thought it was a space issue and tried to split the input but this doesn�??t help.
For ex the output when I run the tool directly and in the python window is out1
Direct tool
arcpy.MosaicToNewRaster_management("L:/Data_Admin/temp_dataset_storage/LiDAR/FinalSupply/Atherton_Tolga_Walkamin_Mareeba_Bilwon/ASCII_DEM/asc/331000_8120000_1k_1m_DEM_ESRI.asc;L:/Data_Admin/temp_dataset_storage/LiDAR/FinalSupply/Atherton_Tolga_Walkamin_Mareeba_Bilwon/ASCII_DEM/asc/331000_8121000_1k_1m_DEM_ESRI.asc;L:/Data_Admin/temp_dataset_storage/LiDAR/FinalSupply/Atherton_Tolga_Walkamin_Mareeba_Bilwon/ASCII_DEM/asc/331000_8122000_1k_1m_DEM_ESRI.asc;L:/Data_Admin/temp_dataset_storage/LiDAR/FinalSupply/Atherton_Tolga_Walkamin_Mareeba_Bilwon/ASCII_DEM/asc/331000_8123000_1k_1m_DEM_ESRI.asc;L:/Data_Admin/temp_dataset_storage/LiDAR/FinalSupply/Atherton_Tolga_Walkamin_Mareeba_Bilwon/ASCII_DEM/asc/331000_8124000_1k_1m_DEM_ESRI.asc;L:/Data_Admin/temp_dataset_storage/LiDAR/FinalSupply/Atherton_Tolga_Walkamin_Mareeba_Bilwon/ASCII_DEM/asc/331000_8125000_1k_1m_DEM_ESRI.asc;L:/Data_Admin/temp_dataset_storage/LiDAR/FinalSupply/Atherton_Tolga_Walkamin_Mareeba_Bilwon/ASCII_DEM/asc/331000_8126000_1k_1m_DEM_ESRI.asc;L:/Data_Admin/temp_dataset_storage/LiDAR/FinalSupply/Atherton_Tolga_Walkamin_Mareeba_Bilwon/ASCII_DEM/asc/331000_8127000_1k_1m_DEM_ESRI.asc;L:/Data_Admin/temp_dataset_storage/LiDAR/FinalSupply/Atherton_Tolga_Walkamin_Mareeba_Bilwon/ASCII_DEM/asc/331000_8128000_1k_1m_DEM_ESRI.asc;L:/Data_Admin/temp_dataset_storage/LiDAR/FinalSupply/Atherton_Tolga_Walkamin_Mareeba_Bilwon/ASCII_DEM/asc/331000_8129000_1k_1m_DEM_ESRI.asc","P:/2011/Job_106_TRC_FireHazard_Mapping/Working/data/1_Mosaic DEM","Mosaic2","PROJCS['GDA_1994_Transverse_Mercator',GEOGCS['GCS_GDA_1994',DATUM['D_GDA_1994',SPHEROID['GRS_1980',6378137.0,298.257222101]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Transverse_Mercator'],PARAMETER['False_Easting',500000.0],PARAMETER['False_Northing',10000000.0],PARAMETER['Central_Meridian',147.0],PARAMETER['Scale_Factor',0.9996],PARAMETER['Latitude_Of_Origin',0.0],UNIT['Meter',1.0]]","8_BIT_UNSIGNED","#","1","LAST","FIRST")
Python Code - Direct in Arcmap python window
>>> List
['L:\\Data_Admin\\temp_dataset_storage\\LiDAR\\FinalSupply\\Atherton_Tolga_Walkamin_Mareeba_Bilwon\\ASCII_DEM\\asc\\331000_8115000_1k_1m_DEM_ESRI.asc', 'L:\\Data_Admin\\temp_dataset_storage\\LiDAR\\FinalSupply\\Atherton_Tolga_Walkamin_Mareeba_Bilwon\\ASCII_DEM\\asc\\331000_8116000_1k_1m_DEM_ESRI.asc', 'L:\\Data_Admin\\temp_dataset_storage\\LiDAR\\FinalSupply\\Atherton_Tolga_Walkamin_Mareeba_Bilwon\\ASCII_DEM\\asc\\331000_8117000_1k_1m_DEM_ESRI.asc', 'L:\\Data_Admin\\temp_dataset_storage\\LiDAR\\FinalSupply\\Atherton_Tolga_Walkamin_Mareeba_Bilwon\\ASCII_DEM\\asc\\331000_8118000_1k_1m_DEM_ESRI.asc', 'L:\\Data_Admin\\temp_dataset_storage\\LiDAR\\FinalSupply\\Atherton_Tolga_Walkamin_Mareeba_Bilwon\\ASCII_DEM\\asc\\331000_8119000_1k_1m_DEM_ESRI.asc', 'L:\\Data_Admin\\temp_dataset_storage\\LiDAR\\FinalSupply\\Atherton_Tolga_Walkamin_Mareeba_Bilwon\\ASCII_DEM\\asc\\331000_8120000_1k_1m_DEM_ESRI.asc', 'L:\\Data_Admin\\temp_dataset_storage\\LiDAR\\FinalSupply\\Atherton_Tolga_Walkamin_Mareeba_Bilwon\\ASCII_DEM\\asc\\331000_8121000_1k_1m_DEM_ESRI.asc', 'L:\\Data_Admin\\temp_dataset_storage\\LiDAR\\FinalSupply\\Atherton_Tolga_Walkamin_Mareeba_Bilwon\\ASCII_DEM\\asc\\331000_8122000_1k_1m_DEM_ESRI.asc', 'L:\\Data_Admin\\temp_dataset_storage\\LiDAR\\FinalSupply\\Atherton_Tolga_Walkamin_Mareeba_Bilwon\\ASCII_DEM\\asc\\331000_8123000_1k_1m_DEM_ESRI.asc', 'L:\\Data_Admin\\temp_dataset_storage\\LiDAR\\FinalSupply\\Atherton_Tolga_Walkamin_Mareeba_Bilwon\\ASCII_DEM\\asc\\331000_8124000_1k_1m_DEM_ESRI.asc', 'L:\\Data_Admin\\temp_dataset_storage\\LiDAR\\FinalSupply\\Atherton_Tolga_Walkamin_Mareeba_Bilwon\\ASCII_DEM\\asc\\331000_8125000_1k_1m_DEM_ESRI.asc']
>>> arcpy.MosaicToNewRaster_management(List, v1_Mosaic_DEM, 'Name',"PROJCS['GDA_1994_Transverse_Mercator',GEOGCS['GCS_GDA_1994',DATUM['D_GDA_1994',SPHEROID['GRS_1980',6378137.0,298.257222101]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Transverse_Mercator'],PARAMETER['False_Easting',500000.0],PARAMETER['False_Northing',10000000.0],PARAMETER['Central_Meridian',147.0],PARAMETER['Scale_Factor',0.9996],PARAMETER['Latitude_Of_Origin',0.0],UNIT['Meter',1.0]]", "32_BIT_FLOAT", "", "1", "LAST", "FIRST")
<Result 'P:\\2011\\Job_106_TRC_FireHazard_Mapping\\Working\\data\\1_Mosaic DEM\\Name'>
So both processes are loading all the required asc files into the tool but they are not being merged and weirdly the result DEM�??s are in different zones of the band.
I tried to break the files up in to bands as I thought it was a space issue but actually I need each mosaic to be made of about 100 tiles. When I tried the process by splitting into bands, it just processed the first few tiles of each region as in the graphic below. The full script I need to run is attached. The csv_split.py just splits the csv into bands as I initially thought the issue might be lack of space but I have over 250GB of free space on my C: and terabytes on Z:\ (the scratch disc)
Best,
