Intersecting Feature with a Route
2363
04-08-2013 07:11 AM
EricMoody
Just started in with Linear Referencing, and have set up a Route, and was wondering if there is a way to extract information (measure) from the route to another feature, i.e. a culvert intersecting the route to obtain the SLM location of that feature.
Tags (1)
RichardFairhurst
Use the Intersect tool with the points option and the Routes as the primary geometry.  The M value of the intersection will be in the point together with the Route ID and the culvert information.  Calculate the M value to a field using a Python Field Calculator calculation of:
!Shape.Centroid.M!
