I can't copy network analysis objects
3576
01-14-2016 08:39 AM
JúlioLuta
I'm doing my first steps on network analyst. I've created some tests to getting to know how to make all I need for my project.
I needed to copy Lines from my Service Area but it's not working. I'm doing what's described here.
But this is what happens:
In both these tests the copy option is greyed out.
What am I doing wrong?
Thanks in advance,
Júlio
Tags (1)
ChrisDonohue__GISP
What you want to do is export the data, not copy/paste.  Under your Service Area, right-click on Lines and export.  Note - in this example I did the polygons, but you can do the same for Lines.
Once the export process is completed, you will have a feature class.  You can use that feature class with "Copy/Paste" if needed.
Chris Donohue, GISP
ChrisDonohue__GISP
Chris Donohue, GISP
JúlioLuta
Thanks for the reply.
So the information given by ESRI is wrong? I know copy/paste isn't as good, but sometimes might be faster or simpler.
I'm trying to export directly into the geodatabase but I get this error: "Error exporting data. Cannot acquire a schema lock because of an existing lock."
Edit: After restarting ArcGIS this export worked.
