How do you create a 3D arcs that look like flight paths?
2444
10-28-2020 12:18 PM
ToddStanwood
Does anyone know how you create 3D flight paths that look like the arcs in the image below:
Click on link or copy paste in a browser to see the live map:
Train travel times from London | Aspectum
We use ArcGIS Pro and ArcGIS Online.
Todd
Dale_Honeycutt
This is what is called a Spider Diagram.  You can generate these using the Generate Origin-Destination Links  geoprocessing tool.  You'll need to use the Geodetic option for the Line Type parameter as this will produce the 'great circle' lines shown in your graphic.
MeleKoneya
I am interested in doing this too.    I have created Origin-Destination Links but my data is very local.   About 40 miles maximum from origin to destination and much less on average.    I would like to create circular arcs from the origin to the destination like the graphic in this thread but haven't found much that will do that.  I have some arcpy samples but they don't produce the effect desired.   Thank you for any further options.
