Use network analyst extension to create network dataset in ArcGIS from EXOR LRS data
734
02-27-2025 10:44 AM
NaginiAmancherla1
Hi All,
I have the M-aware Linear referencing data (Nodes and line segments) extracted from Bentley's EXOR system.
I could create a network dataset in ArcGIS using the LRS data from EXOR with the ArcGIS Network Analyst extension. I'm able to perform routing using the Network analyst solvers. However, my routes don't consider direction (One-way, Two-way) into account when calculating the routes.  The line segments from the data in EXOR contains fields to indicate the direction of the route, but I'm unsure on how to incorporate the directional component while building the network dataset in ESRI.
We don't have ArcGIS Roads and Highways license. Has anyone taken this path? Links to any resources is appreciated. Thanks in advance.
