Hard Code Question
2663
12-01-2011 05:32 PM
by Anonymous User
Not applicable
Original User: luke.kaim
I need some help to avoid hard coding values. I think that is my problem and why no matter what the input file is I only get a section of the merge. I need to be able to change the inputs and be able to use merge without hard coding anything to work on other data.
arcpy.env.overwriteOutput = True
arcpy.env.workspace = "C:\\Users\\Luke Kaim\\Documents\\university_of_maine\\research4\\test7"
COASTAL_Project_shp__2_ = "COASTAL_Project.shp"
GENERAL_Project_shp__2_ = "GENERAL_Project.shp"
contourPoints_shp = "contourPoints.shp"
APPROACH_SOUNDINGS_Project_shp__2_ = "APPROACH_SOUNDINGS_Project.shp"
# Process: Merge
arcpy.Merge_management([contourPoints_shp,GENERAL_Project_shp__2_,COASTAL_Project_shp__2_,APPROACH_SOUNDINGS_Project_shp__2_], allinputpoints_shp, "SCAMIN \"SCAMIN\" true true false 19 Double 15 18 ,First,#,C:\\Users\\Luke Kaim\\Documents\\university_of_maine\\research4\\contourPoints.shp,SCAMIN,-1,-1,C:\\Users\\Luke Kaim\\Documents\\university_of_maine\\research4\\APPROACH_SOUNDINGS_Project.shp,SCAMIN,-1,-1,C:\\Users\\Luke Kaim\\Documents\\university_of_maine\\research4\\COASTAL_Project.shp,SCAMIN,-1,-1,C:\\Users\\Luke Kaim\\Documents\\university_of_maine\\research4\\GENERAL_Project.shp,SCAMIN,-1,-1;SORDAT \"SORDAT\" true true false 254 Text 0 0 ,First,#,C:\\Users\\Luke Kaim\\Documents\\university_of_maine\\research4\\contourPoints.shp,SORDAT,-1,-1,C:\\Users\\Luke Kaim\\Documents\\university_of_maine\\research4\\APPROACH_SOUNDINGS_Project.shp,SORDAT,-1,-1,C:\\Users\\Luke Kaim\\Documents\\university_of_maine\\research4\\COASTAL_Project.shp,SORDAT,-1,-1,C:\\Users\\Luke Kaim\\Documents\\university_of_maine\\research4\\GENERAL_Project.shp,SORDAT,-1,-1;SORIND \"SORIND\" true true false 254 Text 0 0 ,First,#,C:\\Users\\Luke Kaim\\Documents\\university_of_maine\\research4\\contourPoints.shp,SORIND,-1,-1,C:\\Users\\Luke Kaim\\Documents\\university_of_maine\\research4\\APPROACH_SOUNDINGS_Project.shp,SORIND,-1,-1,C:\\Users\\Luke Kaim\\Documents\\university_of_maine\\research4\\COASTAL_Project.shp,SORIND,-1,-1,C:\\Users\\Luke Kaim\\Documents\\university_of_maine\\research4\\GENERAL_Project.shp,SORIND,-1,-1;DSNM \"DSNM\" true true false 12 Text 0 0 ,First,#,C:\\Users\\Luke Kaim\\Documents\\university_of_maine\\research4\\contourPoints.shp,DSNM,-1,-1,C:\\Users\\Luke Kaim\\Documents\\university_of_maine\\research4\\APPROACH_SOUNDINGS_Project.shp,DSNM,-1,-1,C:\\Users\\Luke Kaim\\Documents\\university_of_maine\\research4\\COASTAL_Project.shp,DSNM,-1,-1,C:\\Users\\Luke Kaim\\Documents\\university_of_maine\\research4\\GENERAL_Project.shp,DSNM,-1,-1;input \"input\" true true false 4 Short 0 4 ,First,#,C:\\Users\\Luke Kaim\\Documents\\university_of_maine\\research4\\contourPoints.shp,input,-1,-1,C:\\Users\\Luke Kaim\\Documents\\university_of_maine\\research4\\APPROACH_SOUNDINGS_Project.shp,input,-1,-1,C:\\Users\\Luke Kaim\\Documents\\university_of_maine\\research4\\COASTAL_Project.shp,input,-1,-1,C:\\Users\\Luke Kaim\\Documents\\university_of_maine\\research4\\GENERAL_Project.shp,input,-1,-1;OBJL \"OBJL\" true true false 19 Double 15 18 ,First,#,C:\\Users\\Luke Kaim\\Documents\\university_of_maine\\research4\\contourPoints.shp,OBJL,-1,-1;VALDCO \"VALDCO\" true true false 19 Double 15 18 ,First,#,C:\\Users\\Luke Kaim\\Documents\\university_of_maine\\research4\\contourPoints.shp,VALDCO,-1,-1;VERDAT \"VERDAT\" true true false 19 Double 15 18 ,First,#,C:\\Users\\Luke Kaim\\Documents\\university_of_maine\\research4\\contourPoints.shp,VERDAT,-1,-1;INFORM \"INFORM\" true true false 254 Text 0 0 ,First,#,C:\\Users\\Luke Kaim\\Documents\\university_of_maine\\research4\\contourPoints.shp,INFORM,-1,-1;MaxSimpTol \"MaxSimpTol\" true true false 19 Double 0 0 ,First,#,C:\\Users\\Luke Kaim\\Documents\\university_of_maine\\research4\\contourPoints.shp,MaxSimpTol,-1,-1;MinSimpTol \"MinSimpTol\" true true false 19 Double 0 0 ,First,#,C:\\Users\\Luke Kaim\\Documents\\university_of_maine\\research4\\contourPoints.shp,MinSimpTol,-1,-1;ORIG_FID \"ORIG_FID\" true true false 0 Long 0 0 ,First,#,C:\\Users\\Luke Kaim\\Documents\\university_of_maine\\research4\\contourPoints.shp,ORIG_FID,-1,-1;Z \"Z\" true true false 19 Double 15 18 ,First,#,C:\\Users\\Luke Kaim\\Documents\\university_of_maine\\research4\\APPROACH_SOUNDINGS_Project.shp,Z,-1,-1,C:\\Users\\Luke Kaim\\Documents\\university_of_maine\\research4\\COASTAL_Project.shp,Z,-1,-1,C:\\Users\\Luke Kaim\\Documents\\university_of_maine\\research4\\GENERAL_Project.shp,Z,-1,-1;id \"id\" true true false 4 Short 0 4 ,First,#,C:\\Users\\Luke Kaim\\Documents\\university_of_maine\\research4\\APPROACH_SOUNDINGS_Project.shp,id,-1,-1")
by Anonymous User
Not applicable
Maybe posting the entire code will help. It does not matter the input file I only get a small section of the merge output.
# testModel.py
#Luke Kaim IDW interpolation
# Import arcpy module
import arcpy, sys, os, re, time
from arcpy import env
from arcpy.sa import *
import arcpy
print "Start time = " + time.asctime()
# Check out any necessary licenses
arcpy.CheckOutExtension("spatial")
# Local variables:
#APPROACH_SOUNDINGS_Clip = "APPROACH_SOUNDINGS_Clip"
#APPROACH_SOUNDINGS_Clip = raw_input("Aproach soundings")
APPROACH_SOUNDINGS_Clip ="C:\\Users\\Luke Kaim\\Documents\\university_of_maine\\research4\\test5\\APPROACH_HARBOR_SOUNDINGS_point.shp"
#GENERAL_Clip = "GENERAL_Clip"
#GENERAL_Clip = raw_input("GENERAL Soundings")
GENERAL_Clip ="C:\\Users\\Luke Kaim\\Documents\\university_of_maine\\research4\\test5\\GENERAL_SOUNDINGS_point.shp"
#APPROACH_POLYGON_Clip = "APPROACH_POLYGON_Clip"
#APPROACH_POLYGON_Clip = raw_input("POLYGON Layer")
APPROACH_POLYGON_Clip ="C:\\Users\\Luke Kaim\\Documents\\university_of_maine\\research4\\test5\\APPROACH_HARBOR_LNDARE_POLYGON_poly.shp"
#COASTAL_Clip = "COASTAL_Clip"
#COASTAL_Clip = raw_input("COASTAL Soundings")
COASTAL_Clip= "C:\\Users\\Luke Kaim\\Documents\\university_of_maine\\research4\\test5\\COASTAL_SOUNDINGS_point.shp"
#APPROACH_ContourLine_Clip = "APPROACH_ContourLine_Clip"
#APPROACH_ContourLine_Clip = raw_input("APPROACH_ContourLine_Clip")
APPROACH_ContourLine_Clip="C:\\Users\\Luke Kaim\\Documents\\university_of_maine\\research4\\test5\\APPROACH_HARBOR_DEPCNT_line.shp"
# Local variables:
COASTAL_Clip__2_ = "COASTAL_Clip"
COASTAL_Clip__4_ = "COASTAL_Clip"
GENERAL_Clip__3_ = "GENERAL_Clip"
APPROACH_POLYGON_Clip__2_ = "APPROACH_POLYGON_Clip"
APPROACH_SOUNDINGS_Project_shp = "APPROACH_SOUNDINGS_Project.shp"
COASTAL_Project_shp = "COASTAL_Project.shp"
GENERAL_Project_shp = "GENERAL_Project.shp"
APPROACH_ContourLine_Project_shp = "APPROACH_ContourLine_Project.shp"
Generalize_ContourLine5meter_shp = "Generalize_ContourLine5meter.shp"
contourPoints_shp__3_ = "contourPoints.shp"
allinputpoints_shp = "allinputpoints2.shp"
Output_Layer__13_ = "allinputpoints_Layer"
allinputpoints_Layer = "allinputpoints_Layer"
allinputpoints_Layer__3_ = "allinputpoints_Layer"
bathymetry = "bathymetryR"
#PolygonFeature = "PolygonFeature"
APPROACH_POLYGON_Project_shp = "APPROACH_POLYGON_Project.shp"
landMask = "Landmask3"
FinishedRast = "DoneRaster"
FinishedRasterACSII_TXT = "ACSII_TXT.TXT"
# Process: Project
arcpy.Project_management(APPROACH_SOUNDINGS_Clip, APPROACH_SOUNDINGS_Project_shp, "PROJCS['NAD_1983_UTM_Zone_19N',GEOGCS['GCS_North_American_1983',DATUM['D_North_American_1983',SPHEROID['GRS_1980',6378137.0,298.257222101]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Transverse_Mercator'],PARAMETER['False_Easting',500000.0],PARAMETER['False_Northing',0.0],PARAMETER['Central_Meridian',-69.0],PARAMETER['Scale_Factor',0.9996],PARAMETER['Latitude_Of_Origin',0.0],UNIT['Meter',1.0]]", "NAD_1983_To_WGS_1984_1", "GEOGCS['GCS_WGS_1984',DATUM['D_WGS_1984',SPHEROID['WGS_1984',6378137.0,298.257223563]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]]")
# Process: Project (2)
arcpy.Project_management(COASTAL_Clip, COASTAL_Project_shp, "PROJCS['NAD_1983_UTM_Zone_19N',GEOGCS['GCS_North_American_1983',DATUM['D_North_American_1983',SPHEROID['GRS_1980',6378137.0,298.257222101]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Transverse_Mercator'],PARAMETER['False_Easting',500000.0],PARAMETER['False_Northing',0.0],PARAMETER['Central_Meridian',-69.0],PARAMETER['Scale_Factor',0.9996],PARAMETER['Latitude_Of_Origin',0.0],UNIT['Meter',1.0]]", "NAD_1983_To_WGS_1984_1", "GEOGCS['GCS_WGS_1984',DATUM['D_WGS_1984',SPHEROID['WGS_1984',6378137.0,298.257223563]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]]")
# Process: Project (3)
arcpy.Project_management(GENERAL_Clip, GENERAL_Project_shp, "PROJCS['NAD_1983_UTM_Zone_19N',GEOGCS['GCS_North_American_1983',DATUM['D_North_American_1983',SPHEROID['GRS_1980',6378137.0,298.257222101]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Transverse_Mercator'],PARAMETER['False_Easting',500000.0],PARAMETER['False_Northing',0.0],PARAMETER['Central_Meridian',-69.0],PARAMETER['Scale_Factor',0.9996],PARAMETER['Latitude_Of_Origin',0.0],UNIT['Meter',1.0]]", "NAD_1983_To_WGS_1984_1", "GEOGCS['GCS_WGS_1984',DATUM['D_WGS_1984',SPHEROID['WGS_1984',6378137.0,298.257223563]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]]")
# Process: Project (4)
arcpy.Project_management(APPROACH_POLYGON_Clip, APPROACH_POLYGON_Project_shp, "PROJCS['NAD_1983_UTM_Zone_19N',GEOGCS['GCS_North_American_1983',DATUM['D_North_American_1983',SPHEROID['GRS_1980',6378137.0,298.257222101]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Transverse_Mercator'],PARAMETER['False_Easting',500000.0],PARAMETER['False_Northing',0.0],PARAMETER['Central_Meridian',-69.0],PARAMETER['Scale_Factor',0.9996],PARAMETER['Latitude_Of_Origin',0.0],UNIT['Meter',1.0]]", "NAD_1983_To_WGS_1984_1", "GEOGCS['GCS_WGS_1984',DATUM['D_WGS_1984',SPHEROID['WGS_1984',6378137.0,298.257223563]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]]")
# Process: Project (5)
arcpy.Project_management(APPROACH_ContourLine_Clip, APPROACH_ContourLine_Project_shp, "PROJCS['NAD_1983_UTM_Zone_19N',GEOGCS['GCS_North_American_1983',DATUM['D_North_American_1983',SPHEROID['GRS_1980',6378137.0,298.257222101]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Transverse_Mercator'],PARAMETER['False_Easting',500000.0],PARAMETER['False_Northing',0.0],PARAMETER['Central_Meridian',-69.0],PARAMETER['Scale_Factor',0.9996],PARAMETER['Latitude_Of_Origin',0.0],UNIT['Meter',1.0]]", "NAD_1983_To_WGS_1984_1", "GEOGCS['GCS_WGS_1984',DATUM['D_WGS_1984',SPHEROID['WGS_1984',6378137.0,298.257223563]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]]")
# Process: Add Field
arcpy.AddField_management(APPROACH_SOUNDINGS_Project_shp, "input", "SHORT", "", "", "", "", "NON_NULLABLE", "NON_REQUIRED", "")
# Process: Add Field (2)
arcpy.AddField_management(COASTAL_Project_shp, "input", "SHORT", "", "", "", "", "NON_NULLABLE", "NON_REQUIRED", "")
# Process: Add Field (3)
arcpy.AddField_management(GENERAL_Project_shp, "input", "SHORT", "", "", "", "", "NON_NULLABLE", "NON_REQUIRED", "")
# Process: Add Field (4)
arcpy.AddField_management(contourPoints_shp__3_, "input", "SHORT", "", "", "", "", "NON_NULLABLE", "NON_REQUIRED", "")
# Process: Calculate Field
#APPROACH_SOUNDINGS =1
#COASTAL_sounding =2
#GENERALSoundings =3
#contourpoint =4
arcpy.CalculateField_management(APPROACH_SOUNDINGS_Project_shp__2_, "input", "1", "PYTHON_9.3", "")
# Process: Calculate Field (2)
arcpy.CalculateField_management(COASTAL_Project_shp__2_, "input", "2", "PYTHON_9.3", "")
# Process: Calculate Field (3)
arcpy.CalculateField_management(GENERAL_Project_shp__2_, "input", "3", "PYTHON_9.3", "")
# Process: Simplify Line
arcpy.SimplifyLine_cartography(APPROACH_ContourLine_Project_shp, Generalize_ContourLine5meter_shp, "POINT_REMOVE", "5 Meters", "RESOLVE_ERRORS", "NO_KEEP", "CHECK")
# Process: Feature Vertices To Points
arcpy.FeatureVerticesToPoints_management(Generalize_ContourLine5meter_shp, contourPoints_shp__3_, "ALL")
# Process: Calculate Field (4)
arcpy.CalculateField_management(contourPoints_shp, "input", "4", "PYTHON_9.3", "")
# Process: Merge
arcpy.Merge_management([contourPoints_shp,GENERAL_Project_shp__2_,COASTAL_Project_shp__2_,APPROACH_SOUNDINGS_Project_shp__2_], allinputpoints_shp)
print"done"
print "End Time =" + time.asctime()
by Anonymous User
Not applicable
Why does this code not work? Is it the variable I am using?
# testModel.py
import arcpy
# Local variables:
# Local variables:
#COASTAL_Clip__2_ = "COASTAL_Clip"
#COASTAL_Clip__4_ = "COASTAL_Clip"
#GENERAL_Clip__3_ = "GENERAL_Clip"
#APPROACH_POLYGON_Clip__2_ = "APPROACH_POLYGON_Clip"
#APPROACH_SOUNDINGS_Project_shp__2_ = "APPROACH_SOUNDINGS_Project.shp"
#COASTAL_Project_shp__2_ = "COASTAL_Project.shp"
#GENERAL_Project_shp__2_ = "GENERAL_Project.shp"
#contourPoints_shp__3_ = "contourPoints.shp"
##Output_Layer__13_ = "allinputpoints_Layer"
##allinputpoints_Layer = "allinputpoints_Layer"
##allinputpoints_Layer__3_ = "allinputpoints_Layer"
##bathymetry = "bathymetryR"
##landMask = "Landmask3"
##FinishedRast = "DoneRaster"
##FinishedRasterACSII_TXT = "ACSII_TXT.TXT"
# Process: Project
#contourpoint =4
arcpy.CalculateField_management(APPROACH_SOUNDINGS_Project_shp, "input", "1", "PYTHON_9.3", "")
arcpy.CalculateField_management(COASTAL_Project_shp, "input", "2", "PYTHON_9.3", "")
arcpy.CalculateField_management(GENERAL_Project_shp, "input", "3", "PYTHON_9.3", "")
arcpy.FeatureVerticesToPoints_management(Generalize_ContourLine5meter_shp, contourPoints_shp, "ALL")
arcpy.AddField_management(contourPoints_shp, "input", "SHORT", "", "", "", "", "NON_NULLABLE", "NON_REQUIRED", "")
arcpy.FeatureClassToShapefile_conversion(APPROACH_SOUNDINGS_Project_shp,arcpy.env.workspace)
# Process: Merge
arcpy.Merge_management([GENERAL_Project_shp,COASTAL_Project_shp,APPROACH_SOUNDINGS_Project_shp], allinputpoints_shp)
print"done"
by Anonymous User
Not applicable
Data part 2
by Anonymous User
Not applicable
Data part 3
