ExportToPDF with Selection in ArcMap
2818
03-06-2012 05:28 PM
by Anonymous User
Not applicable
Original User: WestonSF
I've noticed something odd happening when exporting to PDF using python.
I have an ArcMap document with a parcels layer and a current selection made of one particular parcel. I have changed the selection colour from the standard ArcMap cyan to a yellow, so it looks like this when you make a selection:
[ATTACH=CONFIG]12466[/ATTACH]
When I run a python command like this from ArcMap:
import arcpy
mxd = arcpy.mapping.MapDocument(r"ReportMap.mxd")
arcpy.mapping.ExportToPDF(mxd, r"Report.pdf")
The PDF is fine with the yellow selection showing. But when I run this script when ArcMap is not open the selection colour in the PDF reverts back to cyan for some reason:
[ATTACH=CONFIG]12467[/ATTACH]
I don't know why that happens? I guess something needs to be set in the ExportToPDF parameters?
JeffBarrette
I assume you set the selection symbol via the main selection menu --> selection options.  Try setting your selection symbol at the layer level via the ayer properties symbology tab.  I just confirmed this and it works.
Jeff
by Anonymous User
Not applicable
Original User: mzcoyle
Changing the default highlighting colour is stored in the normal.mxt I believe, not the mxd. I imagine this parameter won't be read when running outside an ArcMap session.
JeffBarrette
Jeff
by Anonymous User
Not applicable
Thanks for the replies.
I changed the selection colour in layer properties as Jeff suggested and it worked!
[ATTACH=CONFIG]12490[/ATTACH]
