Editing an ArcGIS tool to run in IDLE
3844
12-01-2013 07:04 PM
by Anonymous User
Not applicable
Original User: ricketylick
Hello everyone!
I'm working with an ArcGIS tool that converts data such as shapefiles to excel files. Basically, I need to get this ArcGIS tool to run in IDLE by replacing the GetParameterAsText part with a string(I was told this) to bring in a dataset, set a place to send the converted data, and to set the format(CSV). I'm not really certain how to do this as Python is a real challenge for me and I'm running very short on time. I would greatly appreciate it if someone could create the string and then explain how to fit my data in it but I would also be happy with a very strong explanation of how to do it. Essentially, treat it as if you're talking to a five year old(sounds silly, I know) The following is the data but I will also include the .py file as an attachment. Please and thank you!
# -*- coding: utf-8 -*-
   This script will convert a table to an excel spreadsheet. If the third-party
   module xlwt is available, it will use that. Otherwise, it will fall back to
   CSV.
import arcpy
import os
#function
def header_and_iterator(dataset_name):
    """Returns a list of column names and an iterator over the same columns"""
    data_description = arcpy.Describe(dataset_name)
    fieldnames = [f.name for f in data_description.fields if f.type not in ["Geometry", "Raster", "Blob"]]
    def iterator_for_feature():
        cursor = arcpy.SearchCursor(dataset_name)
        row = cursor.next()
        while row:
            yield [getattr(row, col) for col in fieldnames]
            row = cursor.next()
        del row, cursor
    return fieldnames, iterator_for_feature()
#function
def export_to_csv(dataset, output):
    """Output the data to a CSV file"""
    import csv
    def _encode(x):
        if isinstance(x, unicode):
            return x.encode("utf-8")
        else:
            return str(x)
    def _encodeHeader(x):
        return _encode(x.replace(".","_"))
    out_writer = csv.writer(open(output, 'wb'))
    header, rows = header_and_iterator(dataset)
    out_writer.writerow(map(_encodeHeader, header))
    for row in rows:
        out_writer.writerow(map(_encode, row))
#function that exports the file to an xls file.
#The following is xlwt functionality(its a module)
def export_to_xls(dataset, output):
    Attempt to output to an XLS file. If xmlwt is not available, fall back
    to CSV. #CSV means "comma-separated values"
    XLWT can be downloaded from http://pypi.python.org/pypi/xlwt"""
    #xls is a file extension used on computers running Microsoft Windows to identify files created in Microsoft Excel until 2003. Replaced by xlsx for 2007.
    #XLWT is a library to create spreadsheet files compatible with MS Excel
    try:
        import xlwt
    except ImportError:
        arcpy.AddError("import of xlwt module failed")
        return
    # Make spreadsheet.
    workbook = xlwt.Workbook() #creates the workbook
    worksheet = workbook.add_sheet(os.path.split(dataset)[1]) # creates the worksheet in the workbook and splits the path
    #Set up header row, freeze panes
    header_style = xlwt.easyxf("font: bold on; align: horiz center")
    for index, colheader in enumerate(header):
        worksheet.write(0, index, colheader.replace(".","_"))
    worksheet.set_panes_frozen(True)
    worksheet.set_horz_split_pos(1)
    worksheet.set_remove_splits(True)
    # Write rows
    for rowidx, row in enumerate(rows):
        for colindex, col in enumerate(row):
            worksheet.write(rowidx+1, colindex, col)
    # All done. This line saves our data to the output location
    workbook.save(output)
if __name__ == "__main__":
    dataset_name = arcpy.GetParameterAsText(0)
    output_file = arcpy.GetParameterAsText(1)
    format = arcpy.GetParameterAsText(2)
#Determines where to export the data based on file type.
    if format == "CSV":
        export_to_csv(dataset_name, output_file)
    elif format == "XLS":
        try:
            export_to_xls(dataset_name, output_file)
        except:
            import traceback
            arcpy.AddError(traceback.format_exc())
    else:
        raise ValueError("Don't know how to export to %r" % format)
print "FINISHED"
ModyBuchbinder
If I understand you it is extremely simple
Here is an example:
dataset_name = r"C:\temp\name1"
output_file = r: C:\temp\out.csv"
format = "CSV"
Have fun
Mody
