Comparing field values to file names
4294
10
06-15-2011 09:09 AM
by Anonymous User
Not applicable
Original User: SStrand
I have a shapefile which has a hyperlink field populated with .jpg files. What I would like to do is have a python script check the hyperlink field against the folder full of .jpg files to make sure that everything will be linking correctly. Any help would be much appreciated!
by Anonymous User
Not applicable
Original User: rdharles
Can you give an example of what the hyperlink field looks like.
by Anonymous User
Not applicable
C:\Documents and Settings\All Users\Documents\My Pictures\Sample Pictures\Winter.jpg
C:\Documents and Settings\All Users\Documents\My Pictures\Sample Pictures\Sunset.jpg
etc etc
RDHarles
Something like this should do it...
import arcpy, os
arcpy.env.workspace = os.getcwd()
# shapefile that contains hyperlink
shp = "myfile.shp"
# Create SearchCursor for feature class.
rows = arcpy.SearchCursor(shp)
for row in rows:
    # Get the path to the file from field 'hyperlink'
    path = row.getValue("hyperlink")
    # Does that file exist?
    if os.path.exists(path):
        print "Link is OK: "+path
    else:
        print "BROKEN LINK!: "+path
del rows
by Anonymous User
Not applicable
Thank you very much R.D.!
MikeMacRae
Hey, I'm actually trying to do something very similar. I am trying to compare files names from a field called 'PHOTOS' (a string field containing the files names of photos or jpg's). If the record doesn't have a photo name, it will have the string "N/A") and I want to cross reference those names with the file names in a folder. If they match, I want to copy them to another folder.
The above script works great on my file gdb and I can print out the file names. I went further and tried to test for count, but the count function will not work. I think I have my syntax wrong, but I have honestly spent 2 days on tyhis now with various combinations of code and I am getting different errors every time.....this was easier in 9.3.
import arcpy, os
# Feature Class that contains PHOTOS field
shp = "Z:\ESRI\Geodatabase\TEST.gdb\point_FC"
for row in rows:
    # the print path syntax works fine, it's the count that fails....
    path = row.getValue("PHOTOS")
    print path
    if path != "N/A":
        arcpy.GetCount_management(row)
del rows
by Anonymous User
Not applicable
Mike,
I'm confused, what are you trying to get a count of?
MikeMacRae
Mike,
I'm trying to get a count of all the records in the "PHOTOS" field that DO NOT have the value 'N/A" in them....
by Anonymous User
Not applicable
OK.
Here's how to do it:
1.) Do a MakeFeatureLayer
2.) make a selection (SelectLayerByLocation) where PHOTOS != "N/A"
3.) Finally, do the GetCount, but in 10.x, it has to look something like this:
result = str(arcpy.GetCount_management(FILENAME).getOutput(0) )
MikeMacRae
Hey R.D. Thanks a bunch for the tip. I had used this method earlier but I kept getting error. I had narrowed it down to the !=. The selectbyattributes where clause does not like that operator for NOT EQUALS, which is weird, because I have used it in other SQL queries in python.
After your post, I finally clued in to use <> and that works perfectly. Sometimes it's nice to just have someone jog your memory!
