Changing geometries but keeping attributes
5963
04-03-2014 06:01 AM
by Anonymous User
Not applicable
Original User: mconst50
I have a python script that takes a shapefile of points and moves those points to a new location.  The output feature only has FID, ID, and geometry type, is there a way to preserve the attributes from the original shapefile with the new geometries.
Here is the part of the script that moves the feature, which works great:
infc = Saved_Layer
rows = arcpy.da.SearchCursor(infc, ["Easting", "Northing", "Test_Type"])
point = arcpy.Point()
pointGeometryList=[]
for row in rows:
    x = row[0]
    y = row[1]
    TestType = row[2]
    if TestType == 'MTU':
        distance = .3535535
        angle = 45
        (disp_x, disp_y) = (distance * sin(radians(angle)),\
                    distance * cos(radians(angle)))
        (end_x,end_y) = (x + disp_x, y + disp_y)
        point = arcpy.Point(end_x, end_y)
        pointGeometry = arcpy.PointGeometry(point)
        pointGeometryList.append(pointGeometry)
    elif TestType == 'TU':
        distance = .707107
        angle = 45
# Create feature from geometry list
arcpy.CopyFeatures_management(pointGeometryList, "Points.shp")
fc = "Points.shp"
spatialref = arcpy.SpatialReference(prjfile)
arcpy.DefineProjection_management(fc, spatialref)
I have tried searchcursor, updateCursor,  insertcursor, and spatial joins but when I use the cursor all I get is the first X and Y  repeated in every row. The new geometries only need to include three fields from the original shapefile.
AdamCox1
It would be good if you could use the code tags when you post your question, so your indentation is correctly displayed. For example:
for row in rows:
    a = row[0]
It's especially important to see indentations when the question refers to loops and stuff like that.
Just click the # button and place the formatted text between the tags.
by Anonymous User
Not applicable
Original User: csny490
Yes, just run an update cursor on the shape field. For example: https://arcpy.wordpress.com/2012/11/15/shifting-features/
by Anonymous User
Not applicable
This is my current script:
def shift_features(in_features, x_shift=None, y_shift=None):
    with arcpy.da.UpdateCursor(in_features, ['SHAPE@XY']) as cursor:
        for row in cursor:
            cursor.updateRow([[row[0][0] + x_shift,
                               row[0][1] + y_shift]])
    return
# Set the spatial reference
infc = Saved_Layer
for row in rows:
    x = row[0]
    y = row[1]
    TestType = row[2]
        distance = .3535535
        angle = 45
        disp_x = distance * sin(radians(angle))
        disp_y = distance * cos(radians(angle))
        distance = .707107
        angle = 45
shift_features(infc, x_shift=disp_x, y_shift=disp_y)
I must be doing something wrong because I only now get the points shifted to the distance/angle of TU and the script ignores the MTU statement.
Thanks
by Anonymous User
Not applicable
I used disp_x and disp_y instead of the end_x and y and got all the points.  However, they shifted 100 meters instead of the .3 and .7 meters it should shift depending on the if/elif statement.
Thanks
by Anonymous User
Not applicable
Changed my code to use only one cursor and one function but I am getting this error:
cursor.updateRow([[row[0][0] + distance * sin(radians(45)), row[0][1] + distance * cos(radians(45))]])
TypeError: sequence size must match size of the row
The complete code is:
import arcpy, os, sys
from math import radians, sin, cos
arcpy.env.workspace = "C:/data"
arcpy.env.overwriteOutput = True
def shift_features(in_features):
    with arcpy.da.UpdateCursor(in_features, ('SHAPE@XY', 'Test_Type')) as cursor:
        for row in cursor:
            if row[1] == 'MTU':
                distance = .3535535
            elif row[1] == 'TU':
                distance = .707107
            else:
                print row[1]
                distance = 0
    return 0
#Variables for creating the XY event
infc = r'Database Connections\Test.odc\Units'
x_coords = "Easting"
y_coords = "Northing"
z_coords = ""
out_Layer = "points_layer"
Saved_Layer = "Point.shp"
# Add a spatial reference to the new shapefile
prjfile = "C:/data/LocalGrid.prj"
spRef = arcpy.SpatialReference(prjfile)
# Make the XY event layer...
arcpy.MakeXYEventLayer_management(infc, x_coords, y_coords, out_Layer, spRef, z_coords)
arcpy.CopyFeatures_management(out_Layer, Saved_Layer)
shift_features(Saved_Layer)
# Print feature count and messages
print arcpy.GetMessages()
Been working on this for several days with no success.
