Calculate Field Python Statement
7158
9
08-21-2012 09:48 AM
by Anonymous User
Not applicable
Original User: AndrewRoberts
I have three fields in my attribute table (As seen in 1.jpg, Area1, Area2, and Area3.) I have created a new field and I wish to populate that field with the maximum value between the three fields for each feature. I've done this before with just two fields and it worked great (As seen in 2.jpg.) I tried something like this:
Expression:
Area4(!Area1!, !Area2!, !Area3!)
Code Block:
def Area4(Area1, Area2, Area3):
   if Area1 < Area2:
      return int(Area2)
   elif Area2 < Area 3:
      return int(Area3)
   else:
      return int(Area1)
but it doesn't seem to give me the desired result. I think the null values are what is giving me trouble. Any Ideas?
by Anonymous User
Not applicable
Original User: mdenil
try the max() function
Feed it a non-empty itterable (a string, tuple, or list)....
return max(Area1, Area2, Area3)
casting the returned value to an integer, as you do, will also truncate your floating point number towards zero. That may not be what you want.
by Anonymous User
Not applicable
AndrewRoberts2
The statement
Only works if there is a value for all three areas. If areas 1 and 2 have values but three is null, or any combination of this, then it doesn't work.
If I could convert the <Null>s to zeros then I believe this the 'return max() function' might work.
by Anonymous User
Not applicable
Original User: ttruong
Have you try to use list instead?
MaxVal = []
rows = arcpy.SearchCursor("Your Featureclass")
for row in rows:
 MaxVal.append(row.Area1)
 MaxVal.append(row.Area2)
 MaxVal.append(row.Area3)
 arcpy.CalculateField_management("Your Featureclass", "Area4", max(MaxVal), "VB", "")
curtvprice
The try/except handles the issue where all are null - you'll just get null back.
Calculate Field tool:
Expression:  maxfld(!Area1!, !Area2!, !Area3!)
def maxfld(fld1,fld2,fld3):
  try:
    lst = list()
    for k in (fld1,fld2,fld3):
      if k: lst.append(k)
    return max(lst)
  except:
    pass
by Anonymous User
Not applicable
That's very odd behavior of Field Calculator.  Perhaps you should use script with updateCursor to calculate values for "Area4" if you don't want to calculate all <null> values to 0.
I did a quick test using script and I've got the right values.
import arcpy
rows = arcpy.SearchCursor("D:\Test\test.gdb\DataElements\FrequencyArea")
mylist = []
for row in rows:
    vals = (row.Area1, row.Area2, row.Area3)
    for val in vals:
        if val not in (""," ",None):
            mylist.append(val)
    print max(mylist)
    mylist = []
it returns:
IDLE 2.6.5      ==== No Subprocess ====
6.325
2.1
[ATTACH=CONFIG]17270[/ATTACH]
AndrewRoberts2
Thanks for the help, however in the end I used the original return max(Area1, Area2, Area3) solution but I manually converted my nulls to zeros so that it would work correctly.
by Anonymous User
Not applicable
Original User: brucejr312
As I discovered by helping with another field calculator forum post, you can avoid having to convert null values by
passing the field to the function as integers, strings
def maxNum(num1,num2,num3):
    maxNum = max([num for num in [num1,num2,num3] if num != ''])
    return maxNum
maxNum( int(!Area1!), int(!Area2!), int(!Area3!))
ThaiTruong
This is what exactly I found out at lunch today!  However, it's best to convert them to strings instead.  So you don't lose the decimal points.
by Anonymous User
Not applicable
Actually, it would be best to pass them as int or float.  See below
>>> max(['103','1020'])
'103'
the python max() method can't be relied upon to accurately sort string representations of numbers
