Beginner having trouble importing arcpy
5514
01-28-2014 07:56 AM
by Anonymous User
Not applicable
Original User: ekociuk
Hey everybody, I am looking at python for my first time ever, trying to follow a tutorial to create a shapefile for each unique value in my attribute table for a specific field. The tutorial suggests I write that start of my code like this:
import arcpy
shpfile = "D:\\GIS\\Python_Exparament\\TEST_YEARS.shp"
cursor = arcpy.SearchCursor(shpfile)
for row in cursor:
    print row.YEAR
After I write that section I get an error message saying:
  File "D:/GIS/Python_Exparament/py_script.py", line 1, in <module>
    import arcpy, OS
ImportError: No module named arcpy
Does anybody have any idea why such a message is coming up?
Thanks for your time.
by Anonymous User
Not applicable
Original User: hua17
Hello Eric,
Good looking script so far!
I'd start by making sure you are using the right version of python on your machine (I've had this problem many times). It is possible that you have two installs. I would go to the start menu > All Programs > ArcGIS > Python 2.7 > IDLE (Python GUI) and use that version IDLE to run your script. (Note you may have a different version of python)
On an unrelated note: The error message looks like you have the line "import arcpy, OS" in your script. It's not necessary, but it is good practice to have that on two lines: (also, change "OS" to "os")
import arcpy import os
Let me know if that works or not! Good luck!
MichaelVolz
Esteemed Contributor
What version of ArcGIS Desktop are you using?
What is your operating system?
A couple of questions to start to get a background about your problem.
by Anonymous User
Not applicable
Version 10.1 and Windows 7
MichaelVolz
Are you running this script in IDLE?
by Anonymous User
Not applicable
Hello Eric,
by Anonymous User
Not applicable
Thank you for the help everybody, Got er working good. It is much appreciated!! 🙂
