arcpy not accepting irregular kernel files
3251
12-12-2013 07:07 AM
by Anonymous User
Not applicable
Original User: k_kent1
I'm trying to perform focal statistics on a raster using a custom kernel, but I keep getting an error when doing so through arcpy. I am using ArcGIS 10.1 SP1 for Desktop: Advanced (build 3143).
The kernel file and process works fine when I do it manually using the focal statistics tool in the spatial analyst toolbox. Also, I have tried using the modelbuilder to create a one step model that does the same and exporting it to a python script, and this also works fine.
However, when I try to write my own script following the examples listed here:
http://resources.arcgis.com/en/help/main/10.1/index.html#//005m00000061000000
and here:
http://resources.arcgis.com/en/help/main/10.1/index.html#//009z000000qs000000
I keep getting error code 010308: Invalid Irregular neighborhood mask.
This is leading me to believe there might be a bug, and not some sort of syntax error on my part, since the software has no problem with this kernel file when using the focal statistics tool in ArcMap.
I have attached my script and kernel file.
Also for reference, here is the text of script that is auto-generated by exporting the model doing the same process, which works just fine.
###this auto script works, the attached one does not
# Import arcpy module
import arcpy
# Check out any necessary licenses
arcpy.CheckOutExtension("spatial")
# Local variables:
small_alt_ras = "C:\\aa\\small_alt_ras"
model_out = "C:\\aa\\output\\model_out4"
# Process: Focal Statistics
arcpy.gp.FocalStatistics_sa(small_alt_ras, model_out, "Irregular C:\\aa\\y_right_kernel.txt", "SUM", "DATA")
