Will not georectify
3992
02-17-2016 09:59 AM
JillWilliams
I have put the georeferenced control points onto my target layer (scanned image in jpg format), the Total RMS Error is 0.813546 with four links. It is linked to an ortho raster image.  BUT, it will not let me rectify. In the save as dialog, I leave alone the cell size, noData as, the resample type (nearest neighbor).  When I try to enter the output location, it cannot be entered. No matter what kind of folder I try to save it in, it tells me that 'object not found' and I cannot change the show of type.  What am I doing wrong?
Thanks
Jill
JayantaPoddar
In Output Location option, you should select a basic folder / Geodatabase and click ADD. Do not enter any FileName in it.
Think Location
DanPatterson_Retired
You have 4 points, but you specify what order of rectification you are using, I am wondering if is a simple as not enough points for the type chosen
Fundamentals of georeferencing a raster dataset—Help | ArcGIS for Desktop
JillWilliams
It is a 1st order polynomial and it did not help adding more points.
ChrisDonohue__GISP
To expand on what Dan Patterson pointed out, from the link he posted:
The number of the noncorrelated control points required for this method must be 1 for a zero-order shift, 3 for a first order affine, 6 for a second order, and 10 for a third order.
Chris Donohue, GISP
JayantaPoddar
Think Location
JillWilliams
Thanks for your suggestion.  I was trying to save it in my geodatabase folders, instead of regular folders. Once I was putting the output files in a regular folder, I could then choose the type of image file to save, and it worked.
