ArcGIS Dashboard ikon is not available
I dont have that ArcGIS Dashboard ikon in my account. I did signed up for a trial license. I have been trying to do an exercise- from ESRI. Build an Interactive Dashboard | Esri Training Tutorial. please advise me what do to. thanks
Hi, i have finished a free course in ArcGIS Pro Basics I passed the test, but the certificate is suspended, what is the reason?
Limiting Access to Data View ONLY
Is there a way to limit users to only have access to Data View as opposed to Layout View in Desktop?
How to idenfity flood areas
Hi all, I'm quite new to Arc so I'm still working things out. Would anybody be able to give me a bit of guidance on how I might identify potential flood areas based on different river level scenarios e.g. were it to rise by 0.2m, which areas in the floodplain would potentially be under water? Any help would be much…
SDE in Oracle Database Environment Training
Hello, We have a programmer in our department who has approached the GIS Team requesting info on different training opportunities associated with the work they do here. This individual does a lot of scripting in PLSQL in an Oracle Environment in which we have an SDE database. We are always banging against different issues,…
Insert polygons to a table
Hello, I have a table of the treatments that we have had for each city in the state. We also have the shapefile for the cities throughout the state. Is there any way that I can join these two datasets based on the city attribute? When I use join, no polygons are connected. Or can you please tell me how we can create a…
I have two separate polygons that are acting as one
I want to clean my data and remove one of these polygons, but it seems that if I try to remove one of them they both get deleted, I was hoping I can split them. I did try using the split tool which got me in even more trouble... I hope the photo attached will make this clear And if on the way anyone can recommend a GIS…
how to add up all the fields in an attribute table
Hi, I'm an undergraduate student doing a dissertation which is very GIS heavy. One of the things I need to do is add up all of the area values in my attribute table to get the total area for a polygon feature class. Is there a quick/easy way for me to do this?
Why can't i see tif image on arcmap 10.2.2 propably made in arcmap 10.0.0 how can i fix it
Even in zoom to layer i cant see the tif image but i can see normaly the jpg images (the tif was made in arcmap 10.0 or 10.2.0 and i'm working on arcmap 10.2.2)
GIS EXAM
I have an upcoming exam which asks the following question. The supplied textbooks do not cover this subject. Any help would be greatly appreciated. You are asked to prepare a map that shows the forest lands that are suitable for harvesting. The lands must not be: 1) within 300 feet of roads and 2)within 500 feet of…
is there a way for arc gis to use attritbute and populate into a form
is there a way for arc gis to use attribute and populate into a form
Continued Development
I just graduated college with a certificate in GIS. I want to continue my career as a GISer, but do not have the funds to purchase ARCmap or any of the other software to continue my skill set. Currently unemployed, I do not want to stay stagnant in my development, but rather want to tone my skills and learn new…
Continuing to Develop GIS Skills
Workshops Coming to Biloxi, MS
If you spend any time at all hanging out on github or on Esri GeoNet, in geotech LinkedIn Groups, or at local DevMeetups and other ArcGIS developer meets you are no doubt aware that the ArcGIS Server API for JavaScript is a hot technology and tool for the developer! Add to that, there’s no doubt that having some additional…
Can't Find Data Set Tutorial in ArcGIS
Anyone, can help me? I can't find data set tutorial in ArcGIS. How I can get it? Specially data set for tracking analysis, spatial analysis,and statistical analysis? If you don't mind, please send an email to me. my email : erna.piantari14@gmail.com
Connect to JSON REST-based web service
Hello, I am trying to connect my GIS database to a JSON REST-based web service. I tried to use the "JSON to Feature" toolset, but probably since it needs to connect through an http link, it didn't go through. Any help is greatly appreciated. Thanks, Aza
Time Duration Quarry
Hi Everyone. I am working on an incident dataset (as shown below), and trying to run a quarry in Select by Attributes. I need to select the incidents (point shapefile) that have lasted more than 15 minutes. Is there any way that I can do it here in ArcGIS? If not, the original dataset was in Excel format. You have any idea…
Converting Date Cells from Excell to ArcGIS
Hi everyone, I am trying to convert a database in Excel format to ArcGIS 10.3.1. I have used Excel to Table tool for this purpose. But the date cells are messed up as below screen shots show. I have tried to save the Excel file as .xls and .csv formats and have played with the format of cells setting them as date and time,…
Excel to ArcGIS
Hi, I have imported and added data from Excel spreadsheet to ArcGIS 10. But when I right click on the data, attribute table is blank. It shows that there exits 22223 records but doesn't show them (as below screen shot shows). Can anyone help me with that please? By the way, I have tried to replace all spaces with…
Field Calculator VB Script
Hi All. I am trying to calculating a field ([Status]) based on another field ([SymbolID]). The code that I am using is as below: Dim Status IF [SymbolID] = '0' THEN Status = 'In Construction' Else Status = 'Planned' EndIf But I keep receiving failure messages. Could you please help me with that? Thanks in advance, Aza
Converting Layer to KML without Losing Attribute Table
Hi! I need to convert Layer to KML (and vice versa). I use the tools embedded in ArcGIS toolbox to do that, but I loose the attribute table. Is there any way to convert without loosing the attributes? Thanks, Aza
cut a roadway between two other intersecting roadways
Hi everyone, I mainly use ArcGIS working with highways and roadways. I need to select and cut a segment of a roadway between two other intersecting roadways, and export it as another layer: as the picture shows, like for example the segment of I-495 btw I-270 and I-95. The way that I do it now, is that I create a polygon…
Will not georectify
I have put the georeferenced control points onto my target layer (scanned image in jpg format), the Total RMS Error is 0.813546 with four links. It is linked to an ortho raster image. BUT, it will not let me rectify. In the save as dialog, I leave alone the cell size, noData as, the resample type (nearest neighbor). When I…
Has anyone come across a metadata editor that will work in 10.2 or 10.3?
Has anyone come across a metadata editor that will work in 10.2 or 10.3? It would be nice if there was a tool that would populate the fields that don’t usually change for me.
Where to Sign Up for Esri's Webinars?
Hello, I was wondering if you guys knew if Esri had a list of webinars? I tried to find it online, but I could not. I just assumed there is one. Maybe there isn't one? I am working towards my GISP, and I know webinars help with building up my points. I am interested in ones that are of course useful to me but also provide…
