Publish trace network feature classes with a trace network layer
2012
03-07-2023 04:57 AM
Acharya
Hello everyone,
I am currently trying to share trace network feature classes with trace network layer. I have created a enterprise database connection and created trace network (It consists of a point feature layer and a line feature layer).
I have followed all the steps to publish this network trace in portal (which is licensed with Trace network). There is no errors while shaing this dataset along with trace network layer as feature service.
Now, I am trying to add trace configuration. When I add the same shared feature layer back in Arcgis Pro, it says that there is no network trace available. However, I can see in rest services that trace network services is also available.
Features available in portal
Features what is visible in rest services.
My Questions:
  • How can I share trace network in arcgis enterprise as feature layer?
  • Why is the trace network visible in rest services but not in feature layer?
  • How can load the trace network back in arcGIS Pro once I have shared the network in arcgis enterprise?
  • Is it possible to edit the trace network after sharing it in arcgis enterprise?
Thank you so much in advance.
JonDeRose
@Acharya  In ArcGIS Pro, when you select the Portal tab from within the Catalog pane and navigate to your trace network service, can you double-click this and see your trace network?
JonDeRose
