Can a Trace Network feature service be added to a web map and used in Experiance builder or Web application Builder?
3077
9
11-16-2023 01:42 PM
DrewDowling
I've published a Trace Network, and I can run traces on it when I  bring it into Pro.
I want to create a field app so crews can run traces in the field. However, when I add the service to a web map, I get an error message in the TOC for the Network layer. No error messages are recorded in the Server or Portal logs.
As a follow on, has anybody gotten the trace network service to work with the Trace widget in Experience builder?
AlixVezina
The Trace widget in Experience Builder only supports Utility Network feature services.
AlixVezina
NicoLuusAU
Anybody know of someone who developed a custom widget for specifically running traces in Experience Builder using the Trace Network Service? I would imagine this is a possibility by using the API.
DrewDowling
Thank you Alix
VanessaSimps
@AlixVezina - looking at this- from the screenshot above, it appears we can't even view the trace network data  in a web map? Is that correct??
AlixVezina
I think if you add it to a map in ArcGIS Pro and then share that map as a web map to your org, it should work as expected.
VanessaSimps
@AlixVezina So I did what you suggested and it does work, but I am confused- if I can't do traces in web apps and maps, how is this useful for the end user? I ask this out of complete curiosity. I am trying to fully understand functionality and use case here and this is confusing to me. Would staff be able to see traces that I run in desktop? or??
AlixVezina
Right now, there are no plans to support Trace Network specific tools on the web. To trace a Trace Network service, you would need to use ArcGIS Pro.
COSPNWGuy
I do hope ESRI reevaluates this position. Trace Network capability is exposed at the server level  - we just need the JS SDK to take advantage of it. Please upvote this idea if interested. There are many use cases where using a UN simply to gain tracing functionality on the web doesn't make any sense. Surface water hydro networks are a good example. They are simple topological networks that need to be traced. They are not a man made utility and don't behave like one. A UN is a lot of bloat for such a simple network.
COSPNWGuy
I also added this idea to the Experience Builder ideas page if you want to upvote.
