Telecommunication Utility Network
5657
6
02-13-2025 12:50 PM
DaniellaRose
Hi all,
I am looking to use the Utility Network for Telecommunications but am struggling to determine if it is worth it as there is not a heap of documentation about it or much user feedback (maybe i am looking in the wrong place too).
If anyone has anything they'd like to share about it or any useful documentation, would be much appreciated.
Daniella
ClaytonBurns2
Hi Daniella, I'm happy to chime in here. I have some thoughts below, but it all boils down to how large is your company, how much if any dedicated GIS staff do you have, and how experienced is that GIS staff at maintaining Enterprise with Portal and maintaining very clean datasets that require a lot of AsBuild time in the office.
The Utility Network Model is very robust and is usable on its own, but really shines when third party companies like Schneider, mPower, 3GIS, CrescentLink, and many others build additional tools like splice editor GUIs, etc. on top of it. That does of course add additional costs though. However, because it is so complex there is a lot of data entry and management that has to be maintained at the AsBuild level to keep the information clean and the model running well.
It usually comes down to a company's size and dedicated GIS workforce on deciding whether it is worth it to use Utility Network. It runs on Enterprise, and I think Portal only still, which are additional software/hardware that need to be maintained or farmed out to someone to maintain for you. ESRI does have a cloud solution they can help with that on.
I work mostly with small rural telecom cooperatives in the midwest and for most of them the Utility Network on Enterprise is not the right solution. To complex of data entry, can't maintain their AsBuilds from the field with Field Maps (most of them are too small to have a dedicated GIS staff person), and most of them can only afford hosting and operating out of ArcGIS Online instead of Enterprise. On the other hand, some of my clients are medium sized telecoms with dedicated GIS staff and they love the utility network with a 3rd party company's add-on.
If you are in this camp of a smaller telecom company, then I'd suggest ESRI's Communications Data Management model https://arcg.is/18SC4K It is similarly structured and will setup a bunch of initial maps, apps, survey's etc. for you. You will still need to update domain lists, symbology, etc. to your company's needs. However, you won't need Enterpirse, it can be hosted on ArcGIS Online only, and since it isn't truly a Utility Network, with traces, splice connections, etc. you can AsBuild directly from the field with Field Maps if needed because you don't have dedicated GIS staff.
Any other questions I'm happy to help. The ESRI telecom staff are really amazing though and will help guide customers down the telecom GIS path that is the right fit for each company and not just try to upsell you on a solution that isn't right for you just for sales. So don't be afraid to reach out to them directly as well.
Best regards,
Clayton
DaniellaRose
I have lots of experience with AGE and UN but not the Telco side of it.
So basically it only really useful if there is a big amount of data?
Thanks
Daniella
YazanSbeih
Hi there,
I would really love to hear your thoughts on a solution we are building for telcos using the UN. Check out the StoryMap and maybe we can connect for more discussions.
Thanks
AyanPalit
@DaniellaRose
Adding some resources since you were looking for documentation.
Geospatially Enabling Telecom: A Complete GIS for Telecommunications
Planning & Engineering NextGen Communication Networks
Communications Utility Network Foundation
Community input from telecom practitioners like @ClaytonBurns2 is invaluable, as you figure out the sweet spot for the ArcGIS solution components.
Ayan Palit | Principal Consultant Esri
KemberlyOReilly
The Utility Network can be a powerful tool for telecoms, especially when paired with third-party solutions that simplify splice management and tracing. For smaller operators though, the complexity and data upkeep can be a challenge.
If you’re exploring practical solutions or want to see how others manage similar setups, Tint Veteran
is worth checking out for some extra resources and guidance.
That said, if your team doesn’t have dedicated GIS staff, lighter frameworks like the Communications Data Management model may be a better starting point since it integrates easily with ArcGIS Online and field apps.
bloxroblox
Hi Daniella, I’ve used Utility Network for telecom a bit — it’s powerful for complex fiber/copper modeling and tracing, but the learning curve is steep and telecom docs are sparse. Esri’s GitHub telecom model and GeoNet are the best places I found useful info.
